Question about GE JE1860 Microwave Oven
Is it worth my time to repair microwave oven?
3 Suggested Answers
  • 4 Answers
SOURCE: GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Posted on Dec 11, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave oven
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you'd want to scan and e-mail or copy and fax the mini-manual (or at least the "schematic diagram page) to me, I'd be happy to make more precise suggestions.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Nov 08, 2008
Push button on microwave has stopped working
It is easy and cheap to fix this, but you need to know about electricity and electronics. Look for a local appliance repair person if you feel it is worth it, but many ovens are so cheap it may not be worth the repair costs.
Oct 09, 2014 | Baumatic BTM23 900 Watts Microwave Oven
I have a KitchenAid microwave model # KCMS185JSS. Everything works except it stopped heating up anything. Is there a separate fuse for the microwave heating? Where is it? can I fix this myself?
Sounds like the microwave's magnet tron (join two words together this page will not allow the correct word) the has gone down. They only last a short time depending on use. Not a great job to do on your own (if you do not know what you are doing) the part cost about 35pounds so most cheap microwaves are not worth repairing, if it is an expensive one it may be worth paying for the repair.
May 26, 2014 | KitchenAid KCMS185J Microwave Oven
Microwave started making a loud noice followed by a burning type smell and slight smoke out of the vent grille Are these units worth having repaired?
Hi, Most of the time not...it costs more then they are worth...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The unit will no longer heat food or beverage
if there is no heating function, chances are that the Magnatron has died. repairs are just not worth the money considering that Microwaves can be oicked uo second hand and with warranty from many Cash converter stores and even some retailers who sell refurbished models from $50
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven turns off
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
It may be worth getting it repaired. Shop around for prices and see if it is worth your while to repair it or simply buy a new one :)
Sep 29, 2008 | Microwave Ovens
Panasonic convection oven,grill and microwave
Sounds like the microwave unit (magnatron) has failed. This will happen if the microwave has ever been used without anything in there to absorb the energy. It basically cooks itself.
Unless you are particularly fond of this unit, it is usually cheaper to buy a replacement than order parts and repair.
You could phone a few local repair centres and ask for a quote , but weigh this against the next thing likely to fail.
Worth repairing industrial models, not really worth repair to domestic models.
Hope this helps you.
Jun 13, 2008 | Microwave Ovens
Emerson MW8107WA Microwave causing apartment fuse blow
It seems that something within the microwave must have fried in the power supply unit. This should not be a very expensive repair, However, get a technician t take a look and give you a rough estimate before you decide to repair.
Dec 17, 2007 | Emerson MW8107WA Microwave Oven
Microwave oven
It may be a door switch, or a failure in the high voltage electronics. Microwave ovens are so cheap these days that they are generally not worth repairing. Do not attempt repair yourself, as there are LETHAL voltages present, even when off & unplugged.
Dec 28, 2006 | Frigidaire FMV145K Microwave Oven
GE JE1860 Microwave Oven Logo
69 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
