Question about Panasonic SC-AK71 Shelf System
Panasonic SA-AK91 Cd player not working loose cable
Scanner/Player moves to right about 1 inch and returns to home position twice. Then "error" appears in display. I noticed loose thin cable about 17" long. I see what appear to be 4 pullys at scanner/player area(2 at top and 2 at botton. I also see a tension spring on left side frame attached to a white plastic holder with other side of spring free.
I assume that the cable is somehow placed on pulley and the end of cable is attached to spring. Any help on the procedure to do this would be greatly appreciated. I don't know if I were to get the service manual if it would show the assembling of the cable. Thank you for your help,Frank
5 Suggested Answers
  • 4 Answers
SOURCE: F61 error in my SA-AK25 Panasonic Audio System
CHANGE STK --------IC
Posted on Mar 27, 2008
zair
  • 82 Answers
SOURCE: SA-AK91-TECHMAN
Recheck the joints of the terminals that join the boards together. Resolder the power supply.
Posted on Mar 29, 2008
  • 75 Answers
SOURCE: how do you put all
press disk 1 open and insert the cd.
now press disc 2 open and insert cd.
same way do the rest.
Posted on Jan 31, 2011
dunnbiker
  • 8546 Answers
SOURCE: my panasonic SA-PM193 died after
... whatever that tells us.
If you severely modified the load to the amp by running more speakers than it's designed to drive and/or at a lower impedence, well, are you surprised?
It only pushes around 25 watts/channel AT TEN PERCENT DISTORTION through a carefully and unrealistically limited bandwidth specification.
http://audio.manualsonline.com/manuals/mfg/panasonic/sc-pm193_1.html?idRes=699618
Running 'clean' (under, say, 1% distortion throughout th 20-20000hz range) it probably only pushes 10 watts/channel. Once an amp is taxed beyond it's clean abilities it will start to distort, badly, and distortion will kill speakers and maybe the amp itself.
Posted on Sep 24, 2011
Can I change Panasonic sa-pt860 DVD player to bluray player?any bluray player can fit into this home theatre?
Most BluRay players will work with home theaters. HDMI cables can be adapted to VGI inputs if necessary.
Dec 09, 2014 | Panasonic Televison & Video
Can Panasonic saht70 play blueray disc
1) you must get the support via ONLINE chat from the manufacturer to see if possible to play blue ray disc 2) the same way get the manufacturer some schem how to connect the speaker without the player.
God bless you
Nov 25, 2013 | Panasonic Sa-ht70 Home Theater Receiver 5...
Fujitsu scanner light bar will not return to
When you face such errors, please check if the Scanner panel displays-"E-0" and TWAIN displays- “The running system is abnormal. Please confirm the carrier lock has come off.”
The error is Carrier unit drive alarm. After power-on, carrier unit (FB) moves to home position, that is where the carrier unit locates when home position sensor is turned ON. If the home position sensor is not turned ON after the carrier unit has moved pre-defined steps, this error occurs.
Probable causes:
Defective sensor, motor, or carrier belt.
Also, please check the following:
1. Is there is any abnormal noise from FB motor when this error occurs?
2. Does any foreign object get inside drive unit or carrier unit?
3. Is CR belt tension loose? Loose belt should be tightened.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Mar 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
Green tint?
you have a bad video cable and its only allowing green and not red and blue, if changing the cable does not do the trick the you video controler in the dvd player or stereo has go bad, might try pluging dvd player into tv directly. that will help you determine if its the player or stereo. good luck
Jun 13, 2009 | Panasonic Audio Players & Recorders
Scanner belt slipping
Check flatcable connection to main circuit board:
Open cover and release the "Z" cover (right side) which hides the flatcable. Simply stick the cable to mainboard.
Feb 20, 2008 | Brother MFC 240C All-In-One InkJet Printer
  1. its eye unit may in trouble, clean eye by using a eye cleaning cd
  2. eye alignment is failed, adjust the eye by adjust the screw on the eye
  3. cable may loose contact, re fix cable, check cable replace cable if necessary
  4. low power supply problem, check supply voltage, if it low simply add a filter capacitor of 4700uF/40V accross it.
  5. some time its main board may problem, check and replace it
Jan 16, 2008 | Audio Players & Recorders
SA-AK91-TECHMAN
Jan 13, 2008 | Panasonic SC-AK71 Shelf System
Scanner not wanting to move
Scanner lock is enabled. Scanner lock is located below scanner where pages come out after printing near the left side. turn it a quarter turn and turn copier off and on again. Should solve problem. If not, then scanner could be dragging on a loose mylar under the glass that guides the ribbon cable. To fix this, you would have to remove the glass.
Nov 25, 2007 | Sharp AL 1631 Copier
Disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Nov 19, 2006 | Panasonic SC-HT680 System
111 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
