Question about Samsung Washing Machines
Samsung model no. Wf328aaw/xaa has error code e3 will not spin
  • 3 Answers
SOURCE: ERROR CODE E3
Here is what it says in Maytag's Technical Info Guide: Machine control is
attempting to drive the
motor but is not seeing any
tach response. Visual
check shows motor is not
moving. (Locked, Hall
Sensor fault)
Here is the web site for the guide:
http://www.servicematters.com/maytag_library/docs/16026736.pdf
Try this: take off the back panel and check the motor connections. Unplug them and look for any corrsion.
Hope this helps.
Posted on Jun 16, 2008
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
  • 380 Answers
SOURCE: samsung washer wf218anb/xaa has code dc and wont
The DC error code is an unbalanced laundry error. Try putting less clothes in and if that doesn't fix the problem, then replace the hall sensor( located behind the drum, underneath the rotor).
Posted on Mar 10, 2010
SOURCE: I purchased a WF328AAW/XAA washer
I am having this same issue. Did you ever find a solution?
Posted on Mar 22, 2011
  • 6277 Answers
SOURCE: samsung model #WF448AAW/XAA will not
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please score accordingly.
Thanks and good luck!
John C
Posted on Apr 13, 2011
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin ยท Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Where is the debris filter in a samsung washer WF328AAW/XAA
you take the plug out
take the back off
it should be between the tub and the pump ((take the hose of and clean it))
Feb 02, 2014 | Samsung WF328AAW Front Load Washer
My samsung washer WF316LAS/XAA has a e3 error code I took the stator off and you can see a smoke or burn spot on it do you think that's the problem?
almost definately. check the resistance across the windings of the stator. they should all be the same. (which they almost definately won't be if theres a burn on there)
Nov 07, 2013 | LG WM2016C
After main washing, stops and can't spin. Gives error E3.
The "E3" error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
Sep 25, 2013 | Washing Machines
How do you install a pump motor on a samsung washer model # WF306LAW/XAA
remove back panel and you should see the pump .remove the clamps on the hoses and there should be 3 bolts securing pump to base, remove with socket, 1/2
Aug 26, 2010 | Samsung WF328AAW Front Load Washer
Washing Machines Logo
81 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
easy alberta
easy alberta
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
