Question about Dryers
My MTN gearsmith heat press is showing Er2 & is nit heating I cant find tech support 4 this brand or help? What should I do?
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: dryer nit heating on any setting and display always says cooling
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
Posted on May 24, 2010
Trying to do a load of washing, and the Er2 code keeps showing. Have closed the lid, still the same, turned off and started again, still showing Er2. What is wrong?
SADLY JUDITH when we do not know the MAKe of your machine we can not begin helping you . Google the error codes for your MAKE, possibly you will find an answer that way
Dec 12, 2016 | Washing Machines
I have an MTN gearsmith 20 liter autoclave. The autoclave tripped the reset button for the GFCI. It will not turn on. Any advice is welcome
it seems to be in the middle of a cycle and needs to finish
but shorting out.so unplug it and inspect the power cord at both ends
you may need to remove a pannel to get to where it gives power
look for any spot that over heated or arcing spots
also the back side of the control pannel
if you find the bad wire you will know right away
hope this helps joe.
Nov 14, 2016 | Washing Machines
Lack of water
Is it filled with water? If yes, then the liquid level sensor has failed in the unit. This will happen normally, but does happen frequently if you have growth in the water reservoir. Call for service. Follow instruction in the manual about flushing the reservoir.
Feb 16, 2014 | MTN Gearsmith New 1500w Commercial...
E-studio 520 copier Jamming
Where is it jamming at and what code is it giving.  Press the clear and -8- buttons at the same time to see code on screen.
Oct 19, 2007 | Toshiba COPIERS E-STUDIO 520 Copier
Dryers Logo
75 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
