Hi, I have a new 24" audiosonic tv & I am having trouble tuning in the channels. I use auto tune & make sure it is set to australia but I can only get channel 31 & all the ABC channels. Help what am I doing wrong?
  • 18 Answers
SOURCE: Sharp Tv, can't tune in channels
Sounds like he accidently put it in parental lock, the remote should have the "key", the user instruction book will have the answer also. Hope this helps
Posted on Aug 17, 2007
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
SOURCE: Sharp TV CX51N3 How to tune channels
Here's the link to the full user manual.
Cheers
Rich
http://support.sharp.net.au/downloads/opmanuals/CX51N3om.pdf
Posted on Jun 01, 2009
  • 5 Answers
SOURCE: How do I tune TV channels on my Sharp CX48G4 TV without a remote control? There is no tuning / settings panel on the TV itself which is very strange.
press the preset button on the front panel once then (TV should be on) the on the screen there should be words the likes of (Auto VHF 1 60.00mhz) now the Auto stands for auto tuning VHF stands for its frequency where its going to search the 1 stands for the channel where its going to start with 60.00mghz stands for the lowest signal to which its going to start now that you have understood all that just press the volume up button then it will automaticly locate all your working channels leave till it stops for when does it will start from channel 1 to which I believe that you be able to see the channel working so press the up button on the channel button to check the rest of your channels hope this will solve your problem!
Posted on Sep 16, 2009
SOURCE: Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Posted on Oct 03, 2009
Toshiba Freeview Tv, Model 19A 615 DB. Re-tuning I pressed Menu, Set-up, Restore Defaults, then Yes to delete previous settings, and OK. Absolutely nothing happens, Help please?
hi,
To Re- tune your TV you have to go to the Auto tuning option in the menu. do the following procedure for auto scan all the available channels.
To tune the free view analogue channels do the following procedure.
1. Press the Menu/setup button on the remote.
2. Select Auto tuning and press enter.
3.Select the country and press enter.
4. Select start and press enter.
The automatic tuning will search for available broadcasts and should store the channels in the correct order. During the search the sound is muted. When all programs have been stored, the normal TV screen will appear.
If you can sent your email address through fixya then i will sent the user manual for Toshiba 19A 615 DB.
ok
Sep 07, 2011 | Televison & Video
Gooman ld2667d tv is not recieving any digital channels, using the same ariel port as before. unplugged the tv to put onto a new stand and getting no digital tv channels. Signal is 0 % too. Before i...
The range and the airial antena have trouble recieving the new location air signal.Try buy a new digital antena and install it.Auto tuning it again.Should work fine.
Aug 12, 2011 | Goodmans 289NS 14" TV
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
I CANNOT TUNE IN MY LG FREEVIEW TV IN WHEN I AUTO TUNE IT IT CANNOT FIND ANY CHANNELS HAD NO PROBLEM BEFORE THE 4TH NOV
Sounds like the digital tuner modual has failed. Check all connections into the TV and make sure secure. Check with another Tv at that location & make sure you have signal. If all checks out with signal & runnning auto program, then you have a faulty tuner.
Nov 07, 2009 | Televison & Video
Tuning option on menu is greyed out. cannot retune channels
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit the icon is not greyed out and tuning is possible.
Sep 30, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Re scanning
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again.
If the channel and other icons are greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit so that the icon is visible again and not greyed out. This will allow you to tune the TV.
Sep 30, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Akai CT21W30AT Manual Tuning
It sets the channel according to the frequency they are on, If you don't have any channels below those numbers and are connected to Cable TV, you have a bad tuner
Mar 13, 2009 | Akai CFT2490 24" TV
Sharp VCR vc-a41 tuning to TV
do you have cable? if yes both tv and vcr should be on ch #3 (to record).......ok no cable you are already set up look at tv right....just need to record..you need your vcr remote.....turn on vcr...press the menu...go to ch settings..auto scan will look for and lock in your channels...also make sure the air/cable selection is on air (unless connected to cable)....hope this helpful....feel free to rate
Oct 14, 2008 | Sharp VC-A410U VCR
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
