Question about Watches
How to remove a split pin in a ari soft gun MP5
Need to remove links on band
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Nov 22, 2010 | Fossil BQ9183 Wrist Watch
Tip
How to remove or add links to watch bracelets.
on Mar 07, 2010 | Watches
How do I remove links on a Movado elliptica?
Jan 08, 2010 | Movado Watches
Remove watch band link
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
Job done!
Don't forget to rate, please.
Jan 26, 2009 | Invicta (2540) Wrist Watch
I need to remove watch links
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
Job done!
Jan 09, 2009 | TechnoMarine RSQC11 Wrist Watch
REMOVING LINKS FROM FOSSIL ARKITEKT MENS WATCH
Job done!
Jan 09, 2009 | Fossil Arkitekt watch
Remove links from watchband.
Job done!
Jan 08, 2009 | Fossil AM3726 Wrist Watch
Remove links from fossil metal band
Job done!
Jan 07, 2009 | Watches
Kenneth Cole Wrist Watch unable to remove link
Job done!
Hope it'll help.
Regards
Arthur
Dec 15, 2008 | Kenneth Cole 1213 Wrist Watch
Removing watch links
Look at both ends of the pin. One will look smooth, the other appears split.
You will need a suitable soft (wooden) support, and a very small dia. punch and a light hammer. The rest of the watch can be protected with a soft cloth.
You place the punch on the end of the pin which looks split, after arranging the watch so the link you are driving the pin from is supported on the edge of the timber. I drill a hole close to the edge of the timber over which I place the pin to be removed. Then by gently tapping the punch with the hammer, the pin should slide down into the hole.
One pin needs to be removed completely, the other can be left in the next link ready to tap back in after the link you wish out is removed.
The important thing is to have a decent punch! The diameter must be such as to fit easily through the pin holes, and the end should be flat. If you cannot make or find a suitable punch, one could be made from something like a darning needle.
Feb 22, 2008 | Watches
Watches Logo
14 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
