Question about Xerox Office Equipment & Supplies
Why am i getting a fault error 042-317 when i turn on my xerox 700i?
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: xerox phasor 8400 - fault 37,004,40:157517"
Hi I can gave you some error codes but this all I can do hope it be of help to you.
8,009.4x:CAP_FAULT_MP_NO_ CLUTCH_STALL:
  • The media path motor has stalled while moving without the clutch engaged.
33,001.4x - TM_DEV_FAULT_MPT_WIDTH_VALUE_TOO_LOW
  • Tray 1 status:
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
08.055.44:
  • The media path drive module has stalled while engaging the head tilt.
37,008.44:
  • The Preheat preheater is not drawing the expected power from the supply.
Run the Preheat Heater test, check the wiring. If test fails and no apparently problem is evident, replace the preheater.
05,002.42:
  • Problems with the Y-axis. It could be the belt,motor or the drum.
7,008.4x: PM_FAULT_HEADTILT_NOT_ ENGAGED
  • The printhead tilt is not engaged, so it didn't tilt back properly or the printhead is stuck in the tilted position by the tilt lock arms. The process motor gear train getting out of sync can also cause this error.
1. Try rebooting the printer.
2. Check for an obstruction or damage in the process gearbox.
3. Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox
assembly.
4. Run the Tilt Axis Drive test to test the headtilt.
5. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
6. Run the Wiper Axis Drive test.
7. Replace the exit assembly.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
  • The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive module shaft are at home position.
6. Verify the headtilt gear will engage, see the home positioning procedure on page. You can manually engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper drive system.
All The Best: Pineworks
Posted on Jan 30, 2010
What does error code 99,013.00:49569 mean xerox 8570 color cube?
Process Drive Fault"
Do you have another kit you can take from another printer.
Switch the printer off.
Swap out the kit with the one from the other printer.
Turn it back on. If it clears the fault when the printer is ready put back the new kit
Aug 14, 2015 | Xerox Office Equipment & Supplies
Anybody know technicians in NJ area for Xerox 700, please
Hi Oscar,
I see you bought a used 700i. I assume you didn't receive a maintenance agreement with the product.
I have some advice for you:
You can purchase a maintenance agreement on Xerox equipment new or used.
First contact:
Xerox Corp
101 Woodcrest Rd, Cherry Hill, NJ 08003
(856) 651-2000
Explain that you have a Xerox 700i without a maintenance agreement
and you would like a certified Xerox Technician to come onsite and
inspect your device to see if it qualifies for a maintenance agreement.
If your device can qualify it is more economically friendly to purchase
an agreement than it would be to have a tech go there and repair it once
Simply put, the one service call could be more expensive than a 1 year
I hope this helps and if you need more info get back to me...
Mar 06, 2015 | Xerox Office Equipment & Supplies
Xerox 700i error code 10-342
10-xx codes are fuser related.
Jul 09, 2014 | Xerox DocuColor 12 Printer
Getting fault error 37,008.44:31508 How
There is a problem with the power up of the printer. For 37,00x.xx error codes you can try power off the printer, wait 30 seconds and power it back on. According to the Xerox website for 37,008:44 error code you should Verify the Printer's Power Source and Isolate the Printer.
Oct 20, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
I get this error 09.038.46:16890, Xerox 8560
9038 Means that the inck count sensor flags are stuck after melting 2.5 ink sticks for your black ink. Are you running Genuine Xerox Ink? If so then you need to run the "Clear ISC Fault" test to clear the error. This is done in the diagnostics menu. To get to the diagnostics menu shut your printer off then do the following.
1.) Hold down the back and info buttons
2.) while holding the buttons turn your printer on
3.) keep holding for 30-45 seconds
The "Clear ISC Fault" is located under the Functions menu.
After you have run the "Clear ISC Fault" verify that the black ink sticks are able to advance in the ink loader chute. Check and make sure there are no broken ink sticks or wrong ink types and remove them.
Mar 19, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox Phaser 8500DN printer error : 09,037.45:67244
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Mar 05, 2009 | Xerox Phaser 8550DX Laser Printer
XEROX 8550 DP ERROR
when are you getting this error message?
Oct 28, 2008 | Xerox Phaser 8550DX Laser Printer
Xerox DC12 Error code 9-355
That is a magenta toner empty message, either the magenta is empty of there is an issue with the magenta toner dispencing.
May 07, 2008 | Xerox DocuColor 12 Color Copier
12 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
