I need to locate air conditioner hoses on my 1999 Chrysler 300M
I need to locate the air conditioner hoses on my 1999 chrysler 300m to put in freon. Where are they?
  • 6,674 Answers
Locate your AC compressor & follow hoses from there. Low side is usually bigger hose.I need to locate air conditioner hoses on my 1999  - e62d1b9.jpg
Posted on Jun 23, 2009
The thermostat don't work where is it located at to put it on the 99 chrysler 300m
Jacquelin! The thermostat n a 3.5 Chrysler 300M is on the block right next to, and toward the front of the engine by the oil filter. Yes, that sems a bit strange, but then I'm not a bit surprised about this engine any more. As the big radiator hose leaves the radiator finding its' way toward the block, it terminates at a traditional "goose neck" at the block behind the power steering pump- only accessible by removing the oil filter and using an extension and a u joint BUT FIRST: lower the anti freeze in the system by draining some fluid. But anyway- THAT'S where it is. Have fun, fix it up and GO!
Dec 12, 2011 | 1999 Chrysler 300M
P1299 code 300m chrysler
code PO1299 = vacuum leak found
check all the vacuum hoses going to the upper intake manafold if all hoses check out ok then replace the idle air control valve.
the onboard computer syatem can not control the idle, it is to idling to high.
Oct 30, 2011 | 1999 Chrysler 300M
Where is the thermostat located on a 1999 chrysler 300m?
The thermostat is located in housing on lower left side of engine block near oil filter and attached lower radiator hose.
hope helps.
Jun 17, 2010 | 1999 Chrysler 300M
Where is the Battery in a 1999 chrysler 300m
It is located under the air filter. On the left side of the engine compartment.
May 10, 2010 | 1999 Chrysler 300M
Need location of coolant sensor on 2002 chrysler 300m
near the thermostat I think, look for this part.
Apr 22, 2009 | 1999 Chrysler 300M
1999 chrysler 300m is overheating and no hot air from heater,can this be the thermostat and if it is where is it located
have you checked to make sure the coolant is full?
the thermostat is located in the housing at the engine, bottom radiator hose
Feb 18, 2009 | 1999 Chrysler 300M
Location of the oilpan and filter of my 1999 Chrysler 300M
there is a large plastic cover/shield under the car, remove it and the filter and oil pan are right there, the filter is in the front.
Dec 04, 2008 | 1999 Chrysler 300M
Heating & Cooling Logo
213 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
