How to set the timing on my 4850 John Deere with a 466 motor
  • 246 Answers
SOURCE: manual John Deere lawnmower
Hello lcurfman:
>>You can obtain Technical Information (operator's manuals, parts catalogs & service / technical manuals);
Call 1-800-522-7448
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
mowerman1857
  • 389 Answers
SOURCE: pto spis all the time on my 1989 john deere 420
Are the blades turning? If they are not, this is normal. The PTO is an electro magnetic clutch that engages when you apply electricity via the PTO switch. When it is disengaged, the bearings and top portion of the clutch will turn because it is coupled to the engine. If the blades ARE turning then you have a bad clutch and will need to repair or replace it
Posted on Sep 18, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
nova2nv
  • 197 Answers
SOURCE: adjusting John deere ''Sabre'' model deck
Move machine to flat/level surface,with deck raised put a 2x4 between rear of deck and ground.Make sure that the 2x4 goes all the way under deck from one side too the other.Once that is done lower deck all the way and make sure lift lever is all the way forward.Then on the rear top side of deck loosen bolt that holds arm to deck bracket,pull bracket as far down as you can then retighten bolt.This is also the point where you can level deck side to side.
Posted on May 05, 2010
  • 6468 Answers
SOURCE: 445 john deere 22hp kawasaki left cylinder won't fire. it used to fire after the motor warmed up but now is dead all the time.
do you have weak spark?is the plug oil fowled?have you done a compression test?
Posted on May 26, 2012
John deere how to find tdc on a 4850
Bring the #1 piston to the top of the cylinder. Remove the dist cap and make sure the rotor is pointing to #1 in the firing order and the balancer marks should line up.
May 04, 2017 | John Deere Garden
Year of my John Deere 466 round baler serial # E00466X144546
You just go to the link I attached I'm sure you will get the solution of your problem.
Best Manuals
Apr 13, 2017 | John Deere Garden
Where is the #1 cylinder located on a 1941 2 cylinder John Deere LA
pull both plugs and rotate motor till you get timing mark to top dead center on marker, feel for compression as you rotate motor BY HAND ONLY that will be #1
Sep 27, 2014 | Cars & Trucks
How do i set timing gears for a john deere 2020
I'd suggest going to John Deere's website and look up an owner's manual and repair manual . If you have Adobe Reader you can copy it in a PDF format.
May 12, 2014 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 9650sts Cam Lobe Motors Technical Manual Ctm19
I got mine from http://manualexpert.com/john-deere-ctm19-component-technical-manual-for-cam-lobe-motors
Nov 11, 2013 | John Deere Garden
Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Oct 25, 2012 | John Deere Garden
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my...
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Aug 06, 2010 | John Deere Garden
My sons peg perego john deere jeep only sets off in second gear what will fix this fault
I would get the Peg Perego Gator Shifter Assembly from http://www.shopjandl.com/
Make sure the wires are secure on both motors in the back.
One time I had the same problem and I had loose wires on the motor, but I ended up replacing the switch assembly later because it would only work in 1st gear.
Hope this helps
Jun 04, 2009 | Peg Perego John Deere Gator HPX Ride on...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
