Question about Goulds Pumps Goulds J5S Jet Pump Shallow Well
I have a cracked pump housing how do i remove the impellar from the motor shaft
Why is the motor roaring ? is it rubing on housing or a bearing ?
It may not be you motor, but the sound of some item caught in the impellar, which is the part that causes suction. It is usually located in the upper housing, and can be accessed fairly easily. Unscrew any visible screws,(usually phillips type) and carefully lift housing off. This should expose the impellar. If debris is present, remove it.
But also check for possibly broken fins on the impellar itself. Sometimes items like coins, or nails etc, will get picked up accidentally, then spin around in the impellar housing, only to break a fin or two trying to move on. If this has happened, replace the impellar.
Dec 22, 2015 | Hoover UH70105 WindTunnel TSeries Bagless...
My pump squeels loudly. I think it's a bearing that I can't get to because I am having trouble getting the impellar off.
If the impeller has never been removed it may not come off. Impellers unthread counter clockwise off the shaft of the impeller by putting a big flat head screw driver on the motor end of shaft.
If they have been on there for years they can become rusted onto the threads of the motor shaft.
At that point if it will not unthread then you will need to break it off.
Rod
US Parts Center
888-521-6183
Feb 09, 2013 | Pool & Spa
I have a Pentair 2.0 pump that I am trying to remove from the impellar. The shaft turns allowing me to turn the pump part itself but I can not pull it loose from the rest of the housing. How exactly do I...
The impeller is threaded onto the motor shaft. On 2hp motors and above, there is usually a screw with reverse threads to help secure impeller to shaft. To remove impeller, first remove screw(reverse threads) Next, remove back cover off motor. The shaft either has a slot for a screwdriver or flats for a wrench. Hold shaft and unscrew impeller.
Aug 21, 2011 | Pentair One - Speed 1hp 115v Dynamo Pump...
I am trying to remove a Centurion B849 from the impeller. I removed the 4 bolts. I come to find out that the shaft is threaded; so in order to rotate the motor, how do I remove the electrical wires on the...
I'm not sure I understand your question.
To get the impellar off of the shaft, leave the motor bolts on.
Open the back end of the motor, there should be a slot in the motor shaft. Use a screwdriver to hold the shaft from rotating and grab the impellar and rotate it counterclockwise to unscrew it.
It sounds easy, but the impellar is probably somewhat corroded on.
Gary
Jun 26, 2011 | AO Smith A O Smith Motors Centurion 1.5hp...
Replaceing the wet end seal on my hot tub
disconnect power take pump out remove front plate take back cover off motor use 7/16 wrench to hold shaft unless it has a place for a flat head screw driver at the back of the motor while holding shaft unscrew impellar counter clockwise take shaft seal off impellar make sure rubber gromet comes off with seal take back seal plate off motor by unscrewing bolts thru back of motor should be 4 knock out ceramic ring replace ceramic ring with rubber side toward plate reinstal back plate install seal on impeller with with flat side with rubber gromet toward back of impellar. screw impeller back on holding shaft if the shaft is rusty and pitted clean off with sand paper b4 reinstalling impellar lube up oring around front plate screw back tight and reinstal pump.
Sep 18, 2009 | Jacuzzi Impeller, L - 3/4 H.P
Jandy jhp .75 hums when you turn it on does not pump
It sounds as if motor is spinning and pump is free so the impellar must not be attached to the motor shaft. There is a set screw on the impellar to hold it to shaft or the pump impellar could be cracked. Only way to tell is take the impellar housing off.
what kind of motor or pump? Hayward, pac flo?
May 28, 2009 | Plumbing
How do i tear down impellar housing on ao smith 2hp bn50 pool motor?
take the impeller housing cover off. the shaft is threaded onto the impeller. Host the shaft and unthread the impeller.David
May 16, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
I have a personal watercraft jet ski kawasaki 1100zx1 and the impeller shaft is frozen. It won't turn. What might be the cause?
only 2 things could be wrong seized motor or bad impellar bearing it is located in the impellar housing you really need to pull the whole impellar housing out of the back of the ski to find out witch one it is
Apr 27, 2009 | Yamaha 12V Air Pump
Pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Sep 25, 2008 | Dishwashers
Goulds Pumps Goulds J5S Jet Pump Shallow Well Logo
81 people viewed this question
Top Goulds Pumps Plumbing Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
ray gallant
Are you a Goulds Pumps Plumbing Expert? Answer questions, earn points and help others
