Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need to find out how to wire starting system - Craftsman 42 in. Deck 19.5hp Lawn Tractor
  • missynunes
    missynunes Oct 05, 2012
    I also need this same diagram, but when I print it, it is so small I can not read it. Could you tell me where else I can find this same diagram?
  • 169 Answers
Need to find out how to wire starting system - 1308d8d.jpg here is a typical starter/solenoid wiring diagram used on all ford lawn tractors and 99 percent of craftsman/ayp mowers hope this helps........
Posted on Nov 23, 2009
Wire a selenoid on riding mower Murray
Posted on Sep 01, 2011
How to bypass the theft system. what color is the theft system wire
There is a good chance that you are in need of a new ignition lock cylinder. There is a small white and orange wire that runs from the lock cylinder, down the column, to a connector under the knee bolster at the base of the column. You can not jump a round this with just a wire as the chip in your key is a resistor. You will need to have a resistor installed inline. A stereo shop that installs remote start systems will be able to assist you.
Nov 19, 2015 | 1998 Chevrolet Cavalier
Original Engine wiring conv. to hei schematic?
Dead simple. Old system used a resistor wire between ign. switch and coil. HEI does not need this so you need to run a 10 or 12 guage wire from the ignition switch "ON" position to the new coil with no resistor in between. This also means you no longer need the extra wire from the starter to the coil which was used to bypass the resistor wire in the old system to provide full 12 volts for starting car. The reason for the resistor wire in the circuit was to reduce the voltage to the coil once running so the amps in the spark would be higher to burn more thoughly and increase fuel mileage.
Apr 23, 2015 | Cars & Trucks
Need to know were wires go
Take it to someplace that installs these things. Wiring on these things depends on features used so anywhere from 15 to sixty wires on the unit plus you need the wiring diagram for the car so you can find out which wires are where and what connects to what. Average install time home user 72 HOURS. Average install time shop that does this.. 1-2 Hours. Your choice.
Mar 09, 2014 | rs3g4 cool start g4 series 1-way remote...
Avital 4103 when i push start button the ignition lights come on but doesn't start the engine
Try leaving the key in the ignition (but don't turn it) and then try. If it starts then you need to properly bypass the transponder system. If not then most likely you don't have your ignition and/or start wires hooked up properly. On many cars there is a second starter wire that needs to be connected
Feb 17, 2013 | 4103LX 4Button Remote Start System with...
What color is the trigger wire between the nuetral safty switch and ignition
You did not specify which the year and model of your Saturn but typically Saturns do not have neutral safety wires that need to be interfaced with a remote start system. Depending on the remote start system being installed will determine the wiring method needed.
Jan 05, 2013 | Security BYPASS Vats Passlock Passlock 2...
I need to bypass my viper remote start system as I
Check ur battery take out any extra wire that hook up to the battery.The system should have no power to the Viper system.U should able to start ur car without the Viper remote.
Apr 21, 2010 | Viper Security and Remote Start System...
How do i wire in a alarm on my 97 suburban K1500 i need a wiring diagram to find wire colors for windows lights and etc........
1997 Chevrolet Suburban Car Alarm Wiring Instructions
Battery Constant 12v+ Positive Wire (+): Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Purple or Yellow
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Pink
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Pink/White Or White (This wire must be connected as ignition #2 for remote starting.)
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Orange
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Brown
Parking Light Positive Wire Location: At Headlight Switch Or In Drivers Kick Panel
Power Door Lock Negative Wire (-): Light Blue (Type A)
Power Door Lock Negative Wire Location: In Either Door Harness
Power Door Unlock Negative Wire (-): White (Type A)
Power Door Unlock Negative Wire Location: In Either Door Harness
Door Trigger Negative Wire (-): Purple
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: White (-), Requires Relay
Domelight Supervision Wire Location: At Headlight Switch
Trunk Release Negative Wire (-): Black (+) Or Black/White (Requires Relay)
Trunk Release Negative Wire Location: At Hatch Release Switch Or Low In Drivers Kick Panel
Horn Negative Wire (-): Black
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): White
Tachometer Wire Negative Wire Location: At ECM. The ECM (electronic control module) is located on the driver side inner fender.
Wait To Start Wire: When hooking up a remote starter on a diesel, you will need to program in the 5, 10 or 15 second wait to start timer in the installation manual. On some vehicles the wait to start light on the dash is not a true (+) positive or (-) negative and the wire from the remote starter will not work.
Wait To Start Location:
Brake Light Positive Wire (+): White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Mar 31, 2010 | Brand Remote Start/keyless/car Alarm Very...
Where to hook up the remote start activation wire?
There is no need to hook up the remote start activation wire. That wire is for testing the system after it has been installed.
Oct 04, 2009 | AviStart 5303 2-Way Security / Remote...
Trying to install a remote start & keyless entry. I need to know where all the wires from the ignition harness go too???
First you will need to research your vehicles under-dash wiring schematic to identify your object wires, color code and function. The schematic may be found in a Y.M.M.(year,make & model) specific, electrical wiring manual. A related search on the internet, or at your local auto dealerships parts department. Then cross-reference and record your vehicles color coded leads to the remote starts color coded leads with respect to their function.
Hope this helps,,,Good luck
Aduz
Mar 27, 2009 | Crimestopper CoolStart(TM) 2-Way Remote...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
1,807 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
