Question about Boating
1994 Yamaha 150HP Outboard
When I running around 4500 to 5000rpms for 5 or 10 minutes the motor (Yamaha TACH) will go off. The low or no oil symbol will go off. As I pull the throttle back to neutral the alarm goes off. The water stream comes out normal. I can ride for 10 or 15 minutes from 5-20mph then the alarm goes off. Sometimes it will go 20 minutes without the alarm doing anything. Any suggestions today I put a new water pump (Impella) on the unit could this help or is it sometime in the tach or oil pump??? thanks help I want to fish thanks
    Champion:
  • 243 Answers
Good Afternoon BayouNola,
This Sounds Like A Loose Connection Problem,
The Tach Is Directly Related To The Charging System,Please Check Your Battery Terminals ,Clean And Secure Tightly To The Battery,
Unplug The engine Electrical Harness Check Clean And Re plug,
Check The Main Fuse For Corrosion And Rectify If Necessary,
If The Engine Was Getting Hot The Alarm Should Be A Continuous Alarm, If It Is a Intermittent Alarm It Is Oil Related !
If In Any Doubt Run With Pre Mixed Fuel,( 500 Ml's In 25 Ltr's Fuel) Until The Problem Is Solved.
Good Luck Gordon
Posted on May 09, 2014
Yamaha outboard 90/65 4stroke jet only getting 5000 rpms. New motor with 6 hours on19' flat bottom boat. Tach is flashing a engine symbol. Suggestions?
The amount of RPM's on a boat motor depend on a number of things...
1. Height if the motor in relation to the bottom of the boat. - too high and it over rev's.. Too low and it won't rev..
2. The correct size (O.D.) of the prop. Too large and you have mechanical interference or too large for the motor to spin...- ..Too small and the motor will over rev!!
3. The correct pitch of the prop. - Too large/big of pitch and the motor can't spin it..-.. too small and it will over rev the motor.
..... these are the big three...
Now, Make sure the carburetor butterfly(s) are opening exactly flat or vertical ...and not under/over opening..if this is a fuel injected motor...have the dealer check it out..
Jul 11, 2017 | Boating
My 2001 johnson 150hp ocean pro outboard starts and runs for a minute then shuts off. Help!
low water flow/pressure, low oil level
crank position sensor or blocked main jets in the carby , low fuel supply
Jul 02, 2017 | Ocean Boating
Help with my 1994 Yamaha 150Hp
Outboards have thermostats...the tattle tale can be pouring water and the engine still overheat if the thermostat is stuck or airlocked.
May 07, 2014 | Boating
Problem with yamaha 50 hp
Check the oil level to see if it's over filled... Use Google for other options.
May 11, 2013 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
50 hp yamaha outboard mid 1990's
2 stroke ?? choking up do you mean ? what oil make and mixture ratio ?
Hello, I wanted to see if you knew what the symbols on the yamaha outboard digital tach are. The one I have does not have any buttons or total hour meter. The symbol I was wondering about is to the left of...
The gauge is for a Yamaha with a remote oil tank. Low oil and no oil. the manual is available at yamaha motors.com. in pdf download format .the year will be almost impossible to find out. the part number can be found at your local dealer. a good parts person can find that by just your description
Oct 24, 2009 | Boating
1984 150hp yamaha outboard is not firing in #5
Stator delivery to the coils.
Sep 20, 2009 | Boating
Downloadable free repair manual
you can download this manual from here.
htttp://freedownloadbook.blogspot.com
Aug 14, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
77 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
