Question about Razor MX350 DIRT ROCKET - BLUE
Power switch doesnt turn on my razor mx 400 - Razor MX350 DIRT ROCKET - BLUE
Razor mx 350 powers on but doesn't run what is the cause of this?
Too many possibilities. Do a google search for "Razor mx 350 repair" or "repair electric bike"
Oct 23, 2015 | Razor Cycling
Why won't my Sharp MX-3501N MFP turn on?
I'm sure you've already figured this out but for anyone who finds this in the future:
Try opening the front cover (where the toner is) and checking the Main Power switch in the bottom left corner under the clear piece of plastic.
If this is on the top power switch should work. If this doesnt take care of it make sure the power is plugged in. If the line is run through a surge protector try plugging it straight into the wall incase the surge protector has gone bad.
www.equipmybiz.com Skelton Business Equipment Houston Copiers
Apr 30, 2014 | Sharp Mx-3501n Color Copier Printer...
My razor mx 500 motor won't turn.
I think you are talking about an electric motor on your bike . If the motor is New you may have a bad throttle switch . You can use an ohm meter to check the throttle switch . Connect the two leads of the ohm meter to the wires of the throttle switch ( dissconected) . As you turn the throttle the ohm reading should coraspond to how much you turn it .
Jan 15, 2018 | Razor MX500 Dirt Rocket
I was given a mx350 that has been sitting in a garage for a year I charged it for 8 hours but it does nothing the light comes on to show it has power but when i turn the throttle nothing no sound or...
If it was working before it sat, then it is almost certainly the battery (these kinds of batteries suffer if sitting and not fully charged). If you had one, or could borrow a voltmeter, you could check the batt. Also, lots of car part places like NAPA can test batteries for you.
Hope that helps
Jul 18, 2011 | Razor MX350 DIRT ROCKET - BLUE
Driver update NVIDIA GeForce2 MX/MX - 400
Go to Nvidia site (www.nvidia.com)
Select "Download Driver" -> "Beta and Archived Drivers"
Next Screen
Three drop down boxes (top to bottom)
Box1: Select "Legacy"
Box2: Select "Gforce2 MX Series"
Box3: Select Gforce 2 MX/MX 400"
Operating system info is the three boxes on the right.
Feb 25, 2011 | Computers & Internet
My razor mx500 is not starting the motor works and battery is charged it just doesnt start up when i turn the throttle
Look hard for loose wires. Start with the on off switch. Make sure all are plugged up. The fuse should be accessible without taking things apart. Water is a major enemy of the solid state box the wires go into before they go to the battery.
Aug 23, 2010 | Razor MX500 Dirt Rocket
I can't find a working sound driver for Windows 7 (Asus K8V-MX)
win 7 is new email motherboard manufacturer or find the chip on the board and search their site or email them with a request for a updated driver win 7 is still nonreleased so alot of stuff doesnt work right till the release micrsoft is not allowing a full working version cause ya know they got to get there 400 dollas out of every last one of us
May 18, 2009 | ASUS K8V-MX Motherboard
Asus A7V8X MX SE loooong beeps
It is either a memory issue or the power supply issue....
Try to reset memory modules.....If the machine still beeps after this and there is different memory modules installed try to remove each and boot(switch on).....to verify if any memory module is faulty.....if this doesnt work try replacing the memory.
If the problem persists try to verify if the power supply is ok.....
Nov 08, 2008 | ASUS A7S8X-MX Motherboard
Razor MX350 DIRT ROCKET - BLUE Logo
57 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
