Question about Husqvarna Garden
Why chainsaw runs well but then dies
Will start up again fine
    Habit-Forming:
    New Friend:
  • 24 Answers
Check fuel filter in fuel tank.
Posted on Feb 26, 2016
picatudo
  • 239 Answers
SOURCE: Chainsaw runs, but dies when given gas.
adjust the gas and air on the two little screws on the carborator
Posted on Dec 31, 2008
  • 246 Answers
SOURCE: chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Posted on Jul 26, 2009
  • 4088 Answers
SOURCE: Why does my poulan chainsaw cuts off
Check the spark plug for condition. It should have a light brown appearance. Check the gap, should be about 0.020". If it looks black and wet, check the air cleaner condition. Check the carburetor mounting and end plate screws for tightness. Check the condition of the fuel lines from inside the tank (tank-end filter too) out to the carburetor for condition. Replace anything that looks cracked or kinked. Check the lines to and from the primer button if the saw has one--no cracks in the primer button itself. Make sure the fuel in the tank is the proper oil mix and is fresh. Always pre-mix oil and fuel before filling the tank. Hope this helps.
Posted on Aug 14, 2009
  • 20 Answers
SOURCE: Chainsaw runs but when I start cutting it dies
you might just neet to clean the air filter and/or the carb.
Posted on Oct 06, 2009
dontbother10
  • 2220 Answers
SOURCE: Chainsaw starts fine, but dies mid cut?
Immediately after saw quits, while everything is still hot. Sometimes ignition modules quit working when hot.
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
Loosen fuel cap when it starts to die, If that fixes it it has a fuel vent problem.
If you did nothing to the carburetor adjustments, are using a fresh (3 months or less) fuel mix with the same oil/fuel ratio, and are operating at the same elevation there is a reason your saw is acting up.
It sounds as though there may be a fuel delivery problem. Check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor. HTH
Lou
Posted on Oct 12, 2009
Chainsaw won't start?
2 possibles
coil is getting hot and failing
do you have spark straight after it stops
is air filter clean
carby diaphragm or carby rebuild required
May 31, 2016 | Garden
Chainsaw dies when cutting tree
Sounds like its starving of fuel, start by replacing the fuel filter in the tank, if no better richen up the H screw on the carb by 1/8 turn out and try again.
Nov 22, 2012 | Garden
Chainsaw cranks and runs but after minute or two it dies. will start again but dies when trying to throttle up
Check the fuel tank vent. Does the saw leak fuel when laying on its side.? Faulty vent can cause the saw to bog down when running
Nov 20, 2012 | Husqvarna Garden
Starts and runs fine, about five minutes then sputters and dies. will not restart until cooled
do cold comp. test if below90psi remove muffler and inspect piston cyl. wall for scroing
Oct 20, 2012 | Poulan 14" Chainsaw
Poulan 16" saw, start fine, runs fine until it
A couple of ideas, it could be a fuel tank breather issue, when it starts to die just try loosening the fuel cap, if the saw picks up again you will need to change the breather, the only other thing i can think of is a bad ignition that is breaking down when hot, the only aswer to this is to replace the ignition unit
Apr 08, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Echo 750 saw runs for two minutes then dies icheck the plug it has gas on it and plug still sparrks put back in starts runs for two minutes or less and dies again?
Could be a fuel tank breather issue, when it starts to die slacken off the fuel cap, to see if it picks up again, if it does you need to replace the breather.
Feb 16, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
My Husqvarna 136 S/N 91VG/56 runs about 1/2 min. then dies. Start it again and it runs about 1min. and dies.
check air leaks between cilinder and carburator, if its ok- fine, check rebuid carburator.
Sep 16, 2010 | Husqvarna Chain Saw 20" Bar
Oct 06, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Chainsaw starts and runs fine for a few minutes
Jul 26, 2009 | Garden
Garden Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
