Question about Hardware & Accessories
How can I get a manual for theben 64B - Hardware & Accessories
How to wire a theben 24hr timer
Generally theben timers are wired same as illustrations shown on following pages
Wiring varies slightly by exact model number.
http://waterheatertimer.org/How-to-wire-DTD-1440-timer.html
http://waterheatertimer.org/How-to-program-Hagar-timer.html
http://waterheatertimer.org/Din-rail-timers-and-manuals.html
Most these timers are rated 15 amp.
Safe maximum :: 15 amp x 80% = 12 amp
230V x 12 amp = 2760 watt
For best long-term result, use timer to turn on a contactor (relay) and let the contactor handle switching heavy amp load
Fuse-protect the timer by adding inline fuse to hot wire going to timer.
Gene
Jul 14, 2014 | General Electric GE 24-Hour Timer, 2-Pin...
can be paper sensor its faulty. reload with diferent paper and reset printer to factory default. try to print pause test without printer connecter to computer.
Feb 17, 2014 | Zebra 2746e Thermal Printer
Can you run office 32 bit on a windows 64 bit operating system?
You have 32-bit Office installation package (CD/DVD/file) and 64-bit Windows operating system. Is it correct?
General answer is YES, I can install a 32-bit application on 64-bit OS. I have exactly same situation in my laptop. Both 32-bit LibreOffice and 32-bit MS Office are installed on W7 & W8 laptops and work well.
But NO vice versa. The 32-bit system does not allow to install 64-bit application. The 32b system does not support 64b instruction set required for 64b applications.
My experience is confirmed by many other users:
Office 32 bit to Windows 7 64 bit
Jan 29, 2014 | Microsoft Windows 7 Professional for PC
The 64B 240v 50Hz 16A theben timer is not turning lights off
Copy following link for analog 24-hour timer:
http://waterheatertimer.org/How-to-set-timers.html
Is this new timer, or older timer with worn-out trippers?
Or is this the theben digital timer.
Add a comment and describe timer in detail for more possible assistance
Apr 20, 2013 | Hardware & Accessories
How to set the time using theben sul 181
how to set the time theben sul 181h and explain its components.
Jul 13, 2011 | Office Equipment & Supplies
Do not know how to use Theben time switch.
I have theben timer sul181h. How to set it for lighting automatically at 6p.m. and stopping at 9p.m.?
Apr 30, 2010 | Hardware & Accessories
Window 7, 64b/t
HP support has software available for Win 7 x64. Also under "Useful Links" there is an HP automatic driver "checker"
HP Color LaserJet 2550LN Downloads
Dec 30, 2009 | HP LaserJet 2550Ln Printer
Drivers for Mustek 1200 UB Plus for Vista 64b
I have a Mustek Plug-n-Scan 1200 UB Scanner. I can't still install it under Windows Vista 64 bit.
Feb 03, 2009 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Hardware & Accessories Logo
35 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
