Question about Asko 24 in. 1805 Built-in Dishwasher
1805 ASKO dishwasher lower rack part number - Asko 24 in. 1805 Built-in Dishwasher
Timon90
  • 126 Answers
SOURCE: Asko 1805 Frozen
Sounds like the controlunit is bad.
Posted on Jan 28, 2008
  • 3 Answers
SOURCE: Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
  1. Unplug or turn off breaker.
  2. Remove kick panel.
  3. Remove water from pan.
  4. plugin/turn on breaker.
  5. watch for leaks.
Posted on May 13, 2009
  • 382 Answers
SOURCE: The top rack on my Asko D1796 dishwasher is defective
call manufactuerer and ask or a good appliance parts and repair they usually are on a spring clip and you just replace the whole roller
Posted on Dec 25, 2009
  • 6 Answers
SOURCE: I need a replacment lower dish rack for Asko 1385
Hi Robinnor,
Most spare parts companies won't hold every item they carry in stock - particuarly if it's for a brand/model number that's a bit uncommon. I would recommend going ahead with your order (even if it's on backorder) - you might be surprised how quickly you can get it, even with it being out of stock.
Posted on Mar 10, 2010
Macmarkus
  • 2605 Answers
SOURCE: all the lights are flashing on Asko 1805 dishwasher
Hi, You need to absorb the water in the overflow basen of the Asko dishwasher's and then push and hold a button to reset the error code...flashing LED's or turn the power off momentarily. You need to remove the lower kick plate and get to the basin with a wet-dry vacuum or sponge etc. Good luck. Let me know if I can assist you further. Thanks for visiting fixya and if you found this solution helpful please rate it accordingly. Macmarkus :)
Posted on Apr 08, 2010
Need replacement control selector pad mounted on top of door Asko 1805 fully integrated
Hello, Welcome to FixYa.
The part you`re looking for on the Asko 1805, as I understand your description ( please correct me if I misunderstood )...
the overlay/decor insert across the top of the control panel is Asko part # 80-708-88 (then a -0 for white or -33 for black depending on the color the last digit?digits change).
Check "repairclinic.com" part number 764259, retail for approx. $80.
Hope that answer`s your question. Let me know if I can assist you further.
Thank you for choosing FixYa today.
Please take a moment to rate the information I provided for you and a testimony if you fell it`s warranted.
Good luck.
Regards,
Macmarkus :)
Sep 04, 2010 | Asko 24 in. 1805 Built-in Dishwasher
Start switch is gone and strip across top of door needs replaced
The part`s you`re looking for, the power switch/on-off switch is Asko original part number 80-575-47. Check "repairclinic.com" part number 763255, retails for approx. $20.
The overlay/decor insert across the top of the control panel is Asko part # 80-708-88 (- 0 for white or -33 depending on the color ). Check "repairclinic.com" part number 764259, retail for approx. $80.
Thank you for choosing FixYa today. Please take a moment to rate the answer I provided for you and a testimony if you fell it`s warranted.
Good luck.
macmarkus :)
Jul 14, 2010 | Asko 24 in. 1805 Built-in Dishwasher
All the lights are flashing on Asko 1805 dishwasher
Apr 08, 2010 | Asko 24 in. 1805 Built-in Dishwasher
I need a replacment lower dish rack for Asko 1385. It is on back order everwhere I can find it.
Hi Robinnor,
Mar 10, 2010 | Asko 1385 Dishwasher
Water Connections
In the US dishwashers are usually connected to the hot water supply. Although the ASKO 1850 I believe has an in line heater. Using hot water supply will reduce electrical useage.
Interestingly we use to have ASKO washer and it suggested only using cold water hook up as it heated its own water. I guess this was a feature if one's laundry area does not have hot supply, but it made no sense in CA to heat water with electricity.
Nov 11, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Asko 1805 dishwasher detergent door does not despense the detergent during the wash cycle. At the conclusion of the dishwasher cycle the door is still closed. How do you repair?
First make sure that nothing is blocking it.. when you load the dishwasher...next make sure your dishwasher cycle is NOT on rince and hold ( water spraying on a plate symbol) as this cycle will not open the despence door..
last you can remove the screws in the door check the vax motor and or check if you are getting power to the despencer ( no power replace control)
power to vax motor replace despencer motor
Hope it helps if Not let me know more about you problem..I can help
Sep 05, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Detergent door will not close on Asko model 1805 dishwasher
Here you must change complete detergent box. Or the electronic gives consantly power to trigger. Most likely one of these two.
Jul 18, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Need upper/lower racks for Asko 1375
An authorized servicer could order them for you but I just priced them and they would cost over $300. You can find a servicer at asko's website.
Jan 02, 2009 | Asko 1375 Dishwasher
  5. watch for leaks.
May 30, 2008 | Asko 24 in. 1885 Built-in Dishwasher
Asko 24 in. 1805 Built-in Dishwasher Logo
43 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
