Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
What does error code f2e0 mean on whirlpool self cleaning range?
fridgetech
  • 473 Answers
SOURCE: The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Posted on Nov 03, 2007
I unplugged the oven and it cleared the code and was able to self clean the oven.
Posted on Jan 07, 2010
fixyourboard
  • 310 Answers
SOURCE: e6 F2 error on Whirlpool double self cleaning oven.
I wrote a blog on this topic recently, perhaps this will help you:
appliancejunk.com/blog/2009/11/11/whirlpool-oven-e6-f2-error-code-failure-andor-blank-display-board-not-available/
Best Regards,
Bruce
www.fixyourboard.com
Posted on Mar 05, 2010
TheMobilian
  • 8220 Answers
SOURCE: self cleaning oven error code FSEO
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 11, 2010
Testimonial: "was surprised at such a quick response...needed additional information to provide a better solution...very grateful for the assistance"
heatman101
  • 43501 Answers
SOURCE: Have Whirlpool self clean electric oven model #
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Jan 20, 2011
Oven Will Not Start
The whirlpool code is that a key button is shorted/stuck. Say's to replace keypad.
Dec 28, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE AND WHEN I TRY THE SELF CLEAN BUTTON I GET F5E1 WHAT IS THE PROBLEM
The F5E1 error codes means that the door light switch OR a switch on the self clean latch has failed. If the oven light comes on and goes off when the door is opened and closed it most likely going to be a switch on the latch thats the problem.
The part numbers are;
DOOR LATCH W10107830
LIGHT SWITCH 3195993
GENE
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
F0E0 error code in Whirlpool self cleaning oven......what does it mean?
Analog to digital failure.
Disconnect panel for 30 seconds
If error re-appears...then replace control
Hope this helps...
Jul 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My oven has an error E1 F5. It was working fine until I tried to use the self cleaner. Now the oven and self cleaner will not work . Only beeps when I try to cut it on.
Hey I found your manual and error codes on-line and was surprised that Whirlpool did not have it hard to reach. Click Here=> Whirlpool 30 in Self-Cleaning Freestanding Electric Range Error Codes
Have questions please ask and rate this solution, Thanks Sea Breeze sea_breeze_128.jpg
or greater.
Error codes are on page 61 section 5-1
Please Rate This Solution, Thank You! Sea Breeze
Mar 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Trying to selfclean oven and getting error code E1 F5. What does that mean?
heatman101
Feb 20, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Error reads F2E0? Can anyone tell me what this means?
Need model off range . Pull out the drawer and is on the side of opening
Nov 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool self cleaning oven problem
Hi
Thanks for using FixYa. This error means that you’ll need to check the door latch/switch and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning oven error code FSEO
Apr 11, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
260 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
