Question about Razor MX500 Dirt Rocket
Charger stays green on my razor dirt bike and get no power to bike
4 Suggested Answers
  • 71 Answers
SOURCE: how do you get the tire of the rear rim of the
i would suggest taking the chain off of the sprocket(cog), then loosening the nuts. then using tire-levers from a bike shop to carefully leve-off the tire. this should work....i have experience with bicycles....i race them! good luck!!!
Posted on Jun 09, 2009
  • 16 Answers
SOURCE: can you put training wheels on a razor 350 dirt
no unless you get them custom made
Posted on Jan 26, 2010
SOURCE: where do i get a battery for a razor dirt bike?
razor.com they have alot of replacement parts
Posted on Dec 31, 2010
When charging my light stays red does that mean its charging
Some chargers have 2 LEDs (lights), some have one. Both chargers have an LED that is red (or orange) when the charger is charging a battery and turns green when the battery is charged and the charger has dropped back to trickle charge mode or off.
On the charger with two LEDs , the extra LED is normally red to indicate the mains power is connected.
Sep 10, 2013 | Razor MX500 Dirt Rocket
Our Razor MX500 won't run with out giving the motor a little help getting going. We took the motor off and hooked it to a battery charger and it works fine, you put it back on the bike and it won&
remember the motor transfer the power to the front..there no weight on the motor when you take it off..the motor can be going bad/a singnal! most people change the battery without checking the motor for wear..
Sep 14, 2012 | Razor MX500 Dirt Rocket
How long do you have to charge it for? , and do i leave it on or off?
the Razor MX350 will accept a charge if powered on or off, charging time is 8 hours, if the green light shows before this time still leave it plugged in as it may not be reading right.
Jun 25, 2011 | Razor MX350 DIRT ROCKET - BLUE
Charger keeps flashing red and green and wont charge
Look at the connector end that plugs into the bike. You might have to take it apart to see the wires inside. My son has a Razor Vespa type scooter and the solder job for the wires inside the connector were not the best. It might be a broken wire, especially if it's flashing between red and green.
Hope this Helps!
Please Rate;)
Gary
May 25, 2011 | Razor MX500 Dirt Rocket
I just replaced the battery, but cannot get power. The "green" light on the charger stays on contstantly. what are the most likely reasons for this problem?
If you have replaced the 3 batteries inside and properly charged them overnight for 18 hours check to see if you have every connector plugged properly. IF you still have no power possibly the control modulator has failed. Is your throttle lighting up when you activate the switch? You can also check to see if the switch itself is working with a voltage meter. Leaving the bike outside in the rain can damage the MX500.
Oct 24, 2010 | Razor MX500 Dirt Rocket
Problem w/ razor dirt quad. I replaced the control module, it ran for a few days then died. Bought another control module and it doesn't go at all. I checked the batteries and they are putting out just...
Well this post was done a long time ago, seems like you have a bad battery. you should see 24vdc. The batteries are in parallel so it adds up to 24 volts.If one of them is dead it would only show 12vdc.
Sep 06, 2010 | Razor Dirt Quad Bike
Off-on switch as bright as when it was new. green light on charger indicates the battery is fully charged. turn throttls and bike barely moves..... ?????
check voltage with a multimeter set on volts before trying to trottle and then after you trottle it should close to the same voltage. If not then you need to replace battery.
Jul 07, 2010 | Razor MX350 DIRT ROCKET - BLUE
Razor MX500 Dirt Rocket Logo
153 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
