Question about Saflok MT3 Electronic Hotel / Motel Lock | New Installs After April, 2011
Where can I find a Saflok Exit Device for Single Point Locks-serial number 842026
Our exit door interior for lock is damaged and need to find replacement part. prong for battery to plug into is damaged
How can I clear locking mechanism?
Only fix is to enter service mode and when you exit it should remove the stored code and allow you to restart unit. If not and you are certified you can call the Tech Line for more assistance. 1-800-662-3587. They will ask you for there account number before helping you. First enter service mode, allow auto test as it will test door locks, fill, drain, and spin functions. When you exit after this test it should allow you to restart the unit as normal. Good Luck
Apr 08, 2016 | Maytag MAH21PDD Commercial Front-Load...
How do I reset the door locks so they all open when I open drivers door to exit. I unlocked the door manually with a key that the electronics are dead
check your fuses you could have one that controls the locks blown out and if that isnt it its probably bad wiring
Feb 19, 2016 | 2006 Dodge Durango SLT
How do i fix my locks,when you insert a key card all three lights i.e. green, orange, red will blink
You should be trained at the hotel by management so they can keep track with what you still need to learn.
Dec 02, 2015 | Saflok MT Electronic Hotel / Motel Lock |...
Locks itself
Happened to me a few times. I do not know the problem, but my personal solution was to always crack the window anytime I exit the car without my keys. This way I can stick my arm in and unlock the door.
Mar 25, 2014 | Honda Accord Cars & Trucks
Kwikset smartcode deadbolt. The lock button unlocks it the code locks it. I followed the handing instructions and tried the bolt in both positions while doing that procedure after the initial problem.
Let's review the programming steps, in case you are overlooking something. This information was found at this link:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Important before proceeding: 1. Verify that position #2 of the "Settings
Switch" is in the OFF position. (Refer to section 11.) 2. Work with the
door open (away from jamb) to avoid accidental lock out. 3. Make sure
the bolt of latch is in the extended (locked) position
8. Automatic - Bolt Direction Determination (Door Handing).
IMPORTANT: DO NOT SKIP THE FOLLOWING STEP.
LOCK WILL NOT BE ABLE TO OPERATE PROPERLY!
? In the steps below, the SmartCode mechanism automatically determines the "door handing" and sets the proper direction for motor to rotate.
a. Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into the interior assembly (the tabs on the pack must face out)
b. When the unit begins to operate the bolt, release the "LOCK" button.
c. Do not disturb the unit for approximately 20 seconds until the interior Green LED flashes followed by a beep. During this time the system will drive the bolt several times, will determine "door handing", store data in memory and exit. It is very important that this process is allowed to finish properly.
Proceed with programming your Usercodes per the instructions.
Finally, here is the contact number for Customer Service At Kwikset. Call them if you still have the problem.
1-800-677-5625
Aug 03, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
I need to change the combo for my fe595 and dont know how. the serial number is 715739 andthe user codes are: A 6152 and B 1514. How do I reprogram the combination?
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Feb 06, 2011 | Schlage Electronic Lock FE595 Plymouth or...
Need to removed from door to change door slab?
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Oct 06, 2010 | Simplex Kaba Ilco Unican LP1000...
How do you change the keyless entry code
You need to key in the original key code, then within 5 seconds press 1/2 button. Key in your new code, then the door locks should cycle to indicate the code has been saved.
Aug 12, 2010 | 2002 Ford Explorer
Door locks stoped working
See if there is a fuse for your door locks.
Good Luck!
Sep 15, 2009 | 2006 Chevrolet Tahoe
Power locks not working right
Hey, this might work.....get in truck, close doors, put key in ignition in lock position.....hold down the door lock button on driver side door control and wait for the lock control to be displayed on the information screen(odometer read-out).....it should say like lock 1, lock 2, lock 3, lock 4.....or something, I always reset mine to LOCK 1, to do this hold the odometer reset button on dash for a sec or two til it changes settings, then release, repeat till you get to LOCK 1, then quickly press and release odometer reset button to exit program, this is the function to lock doors over 15 mph and when out of park and to unlock doors when returned to park......yours' might be set to another function number....try it out, let me know if this helps.........good luck!
Nov 10, 2008 | 2004 Chevrolet Colorado
Saflok MT3 Electronic Hotel / Motel Lock | New Installs After April, 2011 Logo
Top Saflok Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Saflok Lock and Locksmithing Expert? Answer questions, earn points and help others
