A
Anonymous Posted on May 07, 2014
Samson ex250m number of audio output
Michael P
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Nov 10, 2014
Michael P
Contributor
Level 1:
New Friend:
Answers
38
Questions
Helped
8218
Points
99
Samson airline cr 77 receiver has no output
There could be several reasons why your Samson Airline CR77 receiver is not producing any output:
  1. Volume levels: Ensure that the volume levels on the receiver are turned up and not muted.
  2. Output mode: Check if the output mode on the receiver is set to the correct mode (balanced or unbalanced).
  3. Cables: Make sure that the cables used to connect the receiver to the sound board are functioning properly and are plugged in correctly.
  4. Interference: Check if there is any interference from other wireless devices operating in the vicinity. This can cause signal dropouts and affect the receiver's output.
  5. Dead batteries: Check if the batteries in the receiver are charged or need to be replaced. A low battery can cause a drop in output.
If none of these solutions work, you may need to contact Samson's customer support for further assistance or consider taking it to a professional technician for repair.
5answers
Samson G-Track recording volume issue
Try using a computer with a dedicated sound card, not an onboard sound chip. A condenser mike can't provide very much power on its own, and requires power from the attached receiver/amplifier.
Samson Servo 200 Amplifier: Why do my fuses keep blowing?
Some wiring is burnt..ull need to investigate. Causing an overload circuit. Checkout utube or pinterest. Use caution highvolts
I have a Samson XP501i and I want to also hook up a monitor to it. I have a Samson POWERED monitor - 800 watts. Will that work? Or will it blow up my PA?
You can safely connect your powered monitor speaker to either the monitor output jacks or the tape output RCA jacks on your XP510. In addition, you may download the owner's manual here:
https://www.manualslib.com/download/515708/Samson-Expedition-Xp510.html
1helpful
No sound to my headphones with Samson mdr624
First be sue the headphones are good. The C/ROOM + PHONES control is used to set the level sent to the control room outputs, and also to the head-phone jack.
How to connect a samson s mix 5 channel mixer
It depends on what you are trying to connect. The XLR would be a professional type microphone, it does not have phantom so a condenser mic will not work. The other inputs should match your stereo equipment. The output goes to your amp.
The Samson S-Mix is a miniature, rugged 5-channel audio mixer with 4-line inputs and a single XLR microphone input. The line inputs are comprised of two 1/4" phone and stereo RCA phono connections. Each input channel has a rotary volume control and the outputs include stereo RCA phono connectors and 1/4" TRS phone headphone output. The S-Mix is powered with an 18 volt AC adapter.
Hi There, My samson airline wireless 77 mic has stopped working. Can somebody please advise of the best number to reach a samson tech support or service centre on? Thankyou!
Shipping Address:
Samson Technologies Corp.
45 Gilpin Avenue, Suite 100
Hauppauge, NY 11788
Phone Numbers:
Phone: 631-784-2200
Fax: 631-784-2201
Primary E-mail Contacts:
Information - [email protected]
Sales - [email protected]
Support - [email protected]
Literature Requests - [email protected]
Direct Brand E-mail Support:
Samson Wireless - [email protected]
Samson Audio - [email protected]
Hartke - [email protected]
Zoom - [email protected]
International Contacts:
For Samson Audio, Samson Wireless and Hartke please use our International Distributors Page to find the contact information of the Distributor for your country.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Samson servo 300 right channel low output power protection on.Left channel ok.
Hi...
This amp will need to be serviced
Check on the web for someone who does audio/stereo repair in your area
MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Model Number
when you go to control panel on your computer and check on audio and sound devices, is it already set to USB audio CODEC for the default device? did you follow the setup guide or check it? click here for the manual.
update us ok? thanks
 Grubhead
Grubhead
SmartAviator
SmartAviator
