Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
How do I change the bag on the Kenmore Progressive canister vacuum?
How do I change the bag on the Kenmore Progressive Vaccume
3 Suggested Answers
  • 50 Answers
SOURCE: How do you change the bag in a kenmore progressive
There is a latch just under where the hose enters the main canister section, just behind the handle. Pull back on the latch to open the bag compartment. The bag will pull out of it's plastic holder, then slide the new bag all the way in and close the lid.
Posted on Apr 14, 2010
  • 20 Answers
SOURCE: 25512/ 25513 Progressive Canister Vacuum: HI, we have a kenmore progressive canister vacuum ...
cord bad at male prongs, or fuse near motor blown.
Posted on May 06, 2010
How do you change the bag in a kenmore progressive true hepa canister vacuum?
Apr 14, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister vacuum will not turn on
No, the only effect of not cleaning them would be decreased air flow and consequently . The time between changing filters depends on how much the vacuum cleaner is used. Common failures are damaged cords and a damaged or failed power switch
Mar 29, 2010 | Kenmore 23513 Progressive Bagged Canister...
My Kenmore Progressive is making a noise that sounds as if something is blocking the suction. I have checked the tubes and can't find any obvious blockages
Have you changed out the bag? Checked the air filters? When you run it and hold your hand over the hose opening, do you feel suction?
Check the head for blockages, you said the tubes are good, so check the hose, if no obstructions there, open the canister and check the bag, if it's full change it, if not, pull it out and check the filter that's under the bag, if it's not clogged re-run the above steps but this time look for possible vacuum leaks. Let me know if this helps.
Oct 19, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Wiring schmatic for kenmore canistar vacuum
Generally, there are two wires inside the unit which connect to the wiring going down the suction hose.  Since the unit is a/c...it doesn't matter which of them goes to which terminal.  The wires are switched in some cases.  Look for the open terminal.
Dec 19, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Belt repair
if im right on the top where you change the settings for your carpet there should be 2 screws take th e whole top cover off theres a plastic cover for the belt take that off and the rest should be self explanitory
Nov 26, 2007 | Kenmore 25812 / 25813 Progressive Bagged...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
21 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
