Question about Windchaser PACR10 Portable Air Conditioner
I need an exhaust hose - Windchaser PACR10 Portable Air Conditioner
Where can in get a set of exhaust/intake hoses for a danby dpac120068 air conditioner
Is there a reason not to just go to the Danby site? Support Danby includes phone support, email and "Find Parts" Even if their source is out you should at least be able to find the correct part number, then Google Danby (part number).
You could also look to see if generic flexible vinyl tubing/hose can be substituted. It's doubtful that Danby created their own hoses.
Jun 09, 2016 | Danby Heating & Cooling
Does exhaust hose needed for all modes of ac?
Yes. This will exhaust the heat from the condenser and humidity (condensate) from the unit.
Sep 11, 2014 | Haier Heating & Cooling
Amcor portable Air conditioner replacement exhaust hose
I am also looking for a replacement hose for my amcor nanomax portable ac 12000 btu. If I locate one, I will let you know
Jun 26, 2013 | Amcor Heating & Cooling
Amcor KF9000E portable air conditioner manual
My amcor kf9000e has stopped blowing cool air. What could be wrong with it?
May 18, 2012 | Amcor AF9000E Portable Air Conditioner
Hi i have Fujitronic FA-1300 Dual Hose 13000 BTU Portable Air Conditioner the air comes out it not cold does it need gas?
Before assuming it needs to be recharged with refrigerant gas, check the following. As all of these things can affect the cooling,
1. Remove and clean the air intake filter.
2. Check exhaust hoses for obstructions.
3, Exhaust hoses may have to much downward droop. Which doesn't allow the air to exhaust as it
should.
4. check for holes or leaks in the exhaust hoses. Repair or replace the hoses as needed.
5. Check the temperature setting on the controls, as it may be set to high.
If none of the above solves the problem, it may need to be recharged with refrigerant gas. hich is best left to the pros.
I hope this helped you and thanks for choosing FixYa.
Aug 24, 2011 | Heating & Cooling
How does the heater part of the CPN12XH9-E work? Does the hoses need to be in window still?
Yes, hose needs to connect to outdoors, since it operates as a heat pump. You'll notice cold air blowing out the exhaust when in heating mode, and hot air blowing out the exhaust in cooling mode - unit exhausts opposite of temperature you want.
Jun 13, 2011 | Haier HEATER CPN12XH9 Air Conditioner
I need to know how to take the power steering off a 1997 dodge caravan?
Power Steering Pump-Let me know if you need to take the power steering gear off: Removal & Installation 2.4L Engine To Remove:
  1. Disconnect and isolate the negative battery cable.
    • Remove as much fluid as possible from the power steering fluid reservoir using a siphon pump.
    • Remove the drive belt from the power steering pump.
    • Loosen the nut securing the front power steering pump bracket to the aluminum bracket.
    • Raise and safely support the vehicle.
    • Place a drain pan under the vehicle to catch the power steering fluid.
    • Disconnect the connector from the oxygen sensor at the rear engine mount bracket. NOTE: The exhaust system needs to be moved to allow room for power steering pump removal.
    • Remove the bolts and nuts securing the catalytic converter to the exhaust manifold.
    • Disconnect the exhaust system hangers from the brackets. Move the exhaust system rearward and left as far as possible.
    • Raise the heat sleeve to expose the clamp and then disconnect the fluid return hose from the steel tube. Allow the fluid to drain.
    • Remove the accessory drive splash shield.
    • Remove the supply hose coming from the reservoir from the power steering pump. Drain the fluid from the hose.
    • Disconnect the pressure hose from the pump. Drain off excess fluid from the hose.
    • Remove the return hose from the pump. Allow the fluid to drain from the tube.
    • Remove the nut from the rear of the pump to the cast mounting bracket.
    • Loosen the three bolts securing the pump to the front mounting bracket. Then remove the nut and remaining bolt.
    • Remove the power steering pump and the front bracket from the cast bracket on the engine as an assembly through the exhaust tunnel.
    • Remove the three bolts attaching the front bracket to the power steering pump and separate the power steering pump from the front bracket.
To Install:
  1. Install the power steering pump through the exhaust tunnel of the vehicle.
  2. Loosely install the nut on the rear of the pump to hold the pump to the bracket.
  3. Install the front bracket on the pump and install the three bolts loosely.
  4. Install the nut and bolt securing the bracket to the cast bracket.
  5. Tighten the three front bracket-to-pump bolts to 40 ft. lb. (54 Nm).
  6. Connect the pressure hose to the power steering pump. Make sure to inspect the o-ring and replace as needed. Tighten the fitting to 275 in. lb. (31 Nm).
  7. Connect the low pressure return hose to the power steering pump.
  8. Connect the supply hose from the reservoir to the pump. Make sure the hose is not near drive belt.
  9. Install the drive belt and splash shield.
  10. Connect the fluid return hose to the steel tube on the cradle and cover with the heat shield sleeve.
  11. Properly position the protective heat sleeve over the return hose. Secure the heat sleeve with a tie strap to the hose to keep it in place.
  12. Install the exhaust system.
  13. Connect the oxygen sensor wiring connector to the vehicle wiring harness.
  14. Lower the vehicle.
  15. Connect the negative battery cable.
  16. Fill and bleed the power steering system.
  17. Check for leaks.
3.0L Engine To Remove:
  2. Remove as much fluid as possible from the power steering fluid reservoir using a siphon pump.
  3. Remove the drive belt from the power steering pump.
  4. Raise and safely support the vehicle.
  5. Place a drain pan under the vehicle to catch the power steering fluid.
  6. Disconnect the connector from the oxygen sensor at the sensor wiring harness grommet on the floor pan. NOTE: The exhaust system needs to be moved to allow room for power steering pump removal.
  7. Remove the bolts and nuts securing the catalytic converter to the exhaust manifold.
  8. Disconnect the exhaust system hangers from the brackets. Move the exhaust system rearward and left as far as possible.
  9. Raise the heat sleeve to expose the clamp and then disconnect the fluid return hose from the steel tube. Allow the fluid to drain.
  10. Remove the accessory drive splash shield.
  11. Remove the supply hose coming from the reservoir from the power steering pump. Drain the fluid from the hose.
  12. Disconnect the pressure hose from the pump. Drain off excess fluid from the hose.
  13. Remove the two bolts securing the pump to the alternator/power steering pump/belt tensioner bracket.
  14. Remove the pump from the bracket and remove it from the vehicle through the exhaust tunnel on the floor pan.
To Install:
  2. Install the pump on the bracket with the two mounting bolts. Tighten the two bolts to 40 ft. lb. (54 Nm).
  3. Install the pump rear support bracket. Tighten the nut and bolts to 40 ft. lb. (54 Nm).
  4. Connect the pressure hose to the power steering pump. Make sure to inspect the o-ring and replace as needed. Tighten the fitting to 275 in. lb. (31 Nm).
  5. Connect the low pressure return hose to the power steering pump.
  6. Connect the supply hose from the reservoir to the pump. Make sure the hose is not near drive belt.
  7. Install the drive belt and splash shield.
  8. Connect the fluid return hose to the steel tube on the cradle and cover with the heat shield sleeve.
  9. Properly position the protective heat sleeve over the return hose. Secure the heat sleeve with a tie strap to the hose to keep it in place.
  10. Install the exhaust system.
  11. Connect the oxygen sensor wiring connector to the vehicle wiring harness.
  12. Lower the vehicle.
  13. Connect the negative battery cable.
  14. Fill and bleed the power steering system.
  15. Check for leaks.
3.3L & 3.8L Engines To Remove:
  3. Raise and safely support the vehicle.
  4. Disconnect the connector from the oxygen sensor at the sensor wiring harness grommet on the floor pan. NOTE: The exhaust system needs to be moved to allow room for power steering pump removal.
  5. Remove the bolts and nuts securing the catalytic converter to the exhaust manifold.
  6. Disconnect the exhaust system hangers from the brackets. Move the exhaust system rearward and left as far as possible.
  7. Place a drain pan under the vehicle to catch the power steering fluid.
  8. Raise the heat sleeve to expose the clamp and then disconnect the fluid return hose from the steel tube on the cradle. Allow the fluid to drain into the pan.
  9. Remove the accessory drive splash shield.
  10. Remove the drive belt from the power steering pump.
  13. Disconnect the return hose from the pump. Drain the fluid into the drain pan.
  14. Remove the power steering pump rear support bracket.
  15. Remove the three bolts securing the pump to the alternator/power steering pump/belt tensioner bracket.
  16. Remove the pump from the bracket and remove it from the vehicle through the exhaust tunnel on the floor pan.
To Install:
  2. Install the pump on the bracket with the three mounting bolts. Tighten the bolts to 40 ft. lb. (54 Nm).
  3. Install the pump rear support bracket. Tighten the fasteners to 40 ft. lb. (54 Nm).
Oct 13, 2010 | 1997 Dodge Caravan
Air intake via hose & window or intake from room only?
Hello artrey3 The answer is yes, BUT the unit will be exausting room/basement air outside ruining any efficency the unit is rated for.Also you will need makeup/fresh air in the basement. The unit exausting air can put the basement in a vacuum/negitive pressure pulling in air from the chimney!
Jul 09, 2010 | Amana Heating & Cooling
SLOW TO DRY
HI, i recommend making sure that this dryer has a clear exhaust duct and hose. place your hand on the outside exhaust hose and check for a good flow. if the flow is low, you will have some sort of clog in the exhaust system and you will need to clear this blockage. if the exhaust duct and hose is clear of debris, you will the need to check the lint screen for debris as well. make sure you Clean this regularly after every cycle.
I also recommend checking the dryness sensor as well.
May 19, 2009 | Whirlpool LER5636P Electric Dryer
Zanussi TCE7127W - Exhaust air is damp?
Check the exhaust hose for blockage. They normaly need to be cleaned out periodicly
.The exhaust hose is how it gets rid of moisture.
Nov 12, 2008 | Zanussi TC7102W Electric Dryer
Windchaser PACR10 Portable Air Conditioner Logo
16 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Jake's Auto Care...
Steve
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
