Question about Craftsman Garden
Why wont my sears gold 6.75 190 cc no adjustment mower wont stay running?
5 Suggested Answers
  • 246 Answers
SOURCE: no spark
Hello:
>>The Following is a Basic Instruction File I Made for Checking the Coil/Ign Coil/Magnetron/Armature on Small Engines. Any Input is Appreciated.
>>**To Check the Ign Coil; Remove the Spark Plug/s.
>>With a Good Plug, Wrap a Wire Around the Threads of the Plug and Attach the Other End of the Wire to the Engine Block. >>Remove the Blower Housing (metal engine cover). The Wire that is Connected to the Coil/Ign Module from the Shut Off Switch needs to be Removed (unplugged) from the Coil/Ign Module.
>>Now Check for Spark at the Plug.
>>If Spark, then the Shut Off Switch or the Wire is Bad.
>>If Still No Spark, then the Coil/Ign Module is Bad. If there are Safety Switches on this Unit and the Coil is Good; you Need to Check the Safety Switches for Being Bad and Check the Oil Guard Switch also.**
>>The Following is an Instruction File for the Safety Switch System. Any Input is Appreciated.
>>The Color Code of the Wires May be Different than those I Use as a Reference in the Instruction File.
>>**PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed.
>>**Now. On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch (Clutch/Brake) Jumper from Same Color Wire (Example: White to White) First and then Check for Fire, Now Include the Black to Black Wires if No Fire. Check the Clutch/Brake and the Blade/PTO Safety Switches First. Then Check the Oil Guard Switch (if Applicable). Check the Seat Safety Last. Usually the Seat Safety is Not in the System for Starting the Engine. Just to Ensure Someone is in the Seat when Engaging the Transaxle and/or Blades. Use a Paper Clip or a Short Wire to Make a Jumper.**
>>Use a Multimeter and Check the Continuity of the Switch. The Meter should Show when the Contacts are Closed and Open. The Meter will Swing All the Way Over when the Switch Contacts are Closed and Swing Back to the Rest Point when the Switch Contacts are Open.
What is Happening is you are Opening the Carburetor Solenoid when the Harness is Connected and Allowing Just enough Gas to Flow into the Engine and teh Plugs are Not Firing. When you Disconnect the Harness, the Engine Fires because the Safety Swiches cannot Ground Out the Coil with the Coil Shut Off Wire Disconnected (due to the Harness being Disconnected) and Burns the Gas that Entered the Engine when the Carburetor Solenoid was Open.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
  • 110 Answers
SOURCE: won't stay running
Check the gas cap vent. A partial vacuum in the tank will cause these symptoms.
Posted on Nov 02, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a Craftman 675
Hi bencasey48...
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
NOTE: Before you dissemble the carburetor:
Make sure you mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you dissemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel line/s from the carburetor be sure to make a drawing to how the line/s are connected to the carburetor.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 26, 2011
  • 6468 Answers
SOURCE: sears 6 hp will not start
i would look more at the needle and seat (the little valve that aloows the fuel into the carb)
Posted on Apr 26, 2012
Settings for carb. on a 42 cc chain saw
Initial settings are one full turn CCW on both low and high side adjustments.
Sep 02, 2014 | Craftsman sears 18" Chain Saw Chain (...
Sears troubleshooting
I think you mean it wont run after running out of gas. You may have to remove the spark plug and shoot a small shot of starting fluid in the hole and replace the plug. Cranking means turning the engine with the starter motor.
Aug 15, 2014 | Garden
Stay running
The carburetor needs to be adjusted very slightly, with a special tool. If still under warranty bring it to the Sears repair center quickly before you damage the engine.
Jul 07, 2013 | Craftsman 29cc 4Cycle Straight Shaft...
6.25 190 cc mower wont stay started
your running out the gas in the carb out you need to rebiuld the carburator probably dirt in the carb from bad gas
Jul 22, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Sears 6 hp will not start
Apr 24, 2012 | Sears Garden
Won't stay running
Sep 06, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Mower wont stay running
take hose off and take to local hardware store.probly got something that would work
..freaken sears..')
Jun 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
MODEL 5521 RS
hi have a 550 horsepower lawnmower and the height adjuster handle has broke where do i get my hands on a new one anybody out that can help please let me know thanks mossieirwin@hotmail.com
Oct 14, 2008 | Husqvarna 160 CC Honda OHC Engine 21 in
Garden Logo
20 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
