Question about Hoover F5881-900 Vacuum
Scrubbing brushes I have cleaned the filter, checked the dial to make sure it is turned to high and cleaned all of the brushes. Still I can't get the brushes to rotate. What now?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Your turbine might need to be replaced
Posted on Feb 10, 2008
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
The scrubbing brushes do not turn
I would take off the brushes and make sure they are clean. You should be able to mmanually turn them.
Nov 15, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
I bought 2 used filter queens. Does the power head always bog down to the point of stalling out when vacuuming. Very strange for a high end vacuum.
I shouldn't. Check the power nozzle brush to make sure it's clean. Remove thread, hair, etc. that may be wrapped around the brush.
Check the tautness of the belt. If it's too tight it will cause strain on the motor, which will result in this.
Check the ends of the brush. They may need cleaned, or the bearings may need replaced.
I highly recommend taking it to an authorized Filter Queen distrubuter for diagnosis and repair.
There are instructions for replacing the brush at the following site, if you decide to do it yourself.
http://reviews.ebay.com/How-to-install-brushroll-for-Filter-Queen-Vacuum_W0QQugidZ10000000010317007
Mar 02, 2011 | Filter Queen Majestic Canister Vacuum
The spin scrub brushes do not spin.
Try this: Make sure the setting is set to floor, then remove the little window (you might need a flat screwdriver to "pry" it up) and clean off the filter. If there is a blockage, the brushes will not spin! I hope this helps, if so, please give feedback when asked. Thanks, Rene(the VAcuum Doctor)
Nov 09, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a hoover steamvac model # F5915-900 and the brushes are not turning when I turn the selector from off to low or high. I've checked to make sure the brushes are locked in place and they turn manually...
(1) Remove the brush assembly by pulling/unlatching it from base on each side.
(2) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(3) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Sep 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam cleaner spin scrub brushes wont turn cant find belt
Two checks:
(1) Remove the brushes by pulling down on the two ends. Is the squaare drive pin present on top of one brush? It should be about 1/4 inch square, and two inches long. That connects the brush to the drive mechanism.
(2) Remove and clean the inlet filter. It is in a red panel, behind the brushes, under the cleaner. Squeeze the two panel tabs together, and pull down to extend from the base. Cleane the hair/debris from the filter screen.
Sep 13, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover spin scrub machine has stopped scrubbing. It still dispenses and pulls up the water, but the brushes don't move. I've checked the on off button for brush control and cycled it to off and back on,...
There is a filter on the front right hand side of my F5871-900 Hoover. If you remove the plastic covering and clean that filter (wet finger may do), you're Hoover will begin spinning again!
Jul 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes not spinning in Wash mode
take apart the unit at the top (Behind the cleaning fluid container) Inside there is a wire coming up from the motor at the bottom of the unit. This can come unlpugged no longer powering the scrub brushes. Simply slip the wire back on the plug.
To open: remove all visible screws from top half of machine. Remove the rubber mode dial by pulling off, and remove screw behind that. Pull the front off, and the power plugs are located right on the inside of the machine by the mode dial
May 04, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Brushes won't spin
The power wire may be disconnected
Apr 21, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover F5881-900 Vacuum Logo
52 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
