Question about Baldwin Prestige Tobin Right-Handed Dummy Lever Satin Nickel 351TBL
How do I reverse the baldwin tobin dummy lever
I was wondering what the age of our baldwin piano serial #399572 is. thank you for any help
You did not state model, Check the attached links,for your model.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.pianoworld.com/baldwin.htm
Free Piano Age Research
Baldwin Piano Age
Baldwin Pianos Company History Serial Number Search
Mar 10, 2016 | Music
What is my Baldwin spinet serial #1003855 worth?
Baldwins from the 70s and 80s are a bit notorious for various mechanical (and tuning) problems. Most of them pianos were good, but they might have a few parts that were bad, so be aware that you'll need to tune it to sell it, and you may need to do some repair work.
Most prices are listed by model number, not serial number, so you'll need to figure out which model you have. I found a pricing guide, but I don't know how recent it is. There is contact information on the page that might help, though. Baldwin Piano Prices
Jul 19, 2014 | Scripophily.com D. H. Baldwin Company...
Unable to remove old door handle for Baldwin 5255 lever
They are usally pressure fitted, however paint on the door it self will make it stick.
Take an sharp utility knife and score the paint as tight to the
escutcheon as you can, then it should pry off.
Feb 01, 2014 | Baldwin Wave Left-Handed Entry Lever...
The reverse won't work on my singer 9018 sewing machine
STITCHING IN REVERSE
• To reinforce beginnings or ends of seams, push in
reverse lever
(1). Machine will straight stitch in
reverse for as long as you hold the lever in.
• For continuous reverse stitching, push lever in and
slide it to the left to lock. Unlock reverse lever by sliding
it back to the right and letting it return to its normal
position. if you need a manual let me know,,
Nov 25, 2012 | SewShop.com Singer Model 9018 Instruction...
Baldwin door handleset difficult to open due to lever that you push down jiggles instead of being firm to touch
Check to see if there is a set screw on the bottom of the handle. It might be loose.
Sep 08, 2011 | Garden
Looking for the reverse button on a necchi bu nova
There is no reverse button, it is a lever.The stitch length lever also reverses the feed dogs - when down, it runs forward - at zero, it does not feed at all and when moved up, it reverses the machine. Set your stitch length by loosening the thumbscrew on the vertically moving lever and sliding the plate into position while moving the lever up to the desired mark. Tighten the screw and move the lever down to sew - to reverse just move the lever up until it hits the stop to sew the same stitch length in reverse.
Jan 12, 2011 | Necchi 4575 Mechanical Sewing Machine
Thumb latch and component are in tact but it keeps slipping out
when you tighten the screws you have to be sure that the two sides stay aligned. try to tighten the screws a little at a time and keep testing the lever as you go. you will notice that there is a little play frome side to side or up down so it is critcal that you maintatin alignment untill the screws are tight.
Sep 27, 2009 | Baldwin 5445.003.PASS Classic Lever,...
Baldwin 6321 mortise:when locked can open from either side
It sounds as if the lock is installed backwards or more specifically in inside mechanism. The inside lever/handle when turned should retract the deadbolt (safety feature). If yours does not currently switch around.
Feb 02, 2009 | Hardware & Accessories
JVC AV-56WP74 convergence board
This link works for me; http://www.vancebaldwin.com/ hope this helps :) PS your search/security settings must need tweaking if you didn't get that link from google.
Jul 26, 2007 | JVC AV-56WP74 56" Rear Projection...
Baldwin Prestige Tobin Right-Handed Dummy Lever Satin Nickel 351TBL Logo
51 people viewed this question
Top Baldwin Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Baldwin Hardware and Accessory Expert? Answer questions, earn points and help others
