Question about Cub Cadet Garden
My club cadet will start but won't idle, any suggestions
My cub cadet will start but it will not idle and quits.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Rebuild the carb it is dirty jet
Posted on Dec 17, 2014
  • 48 Answers
SOURCE: I cant start my cub cadet cc989
sounds like a plugged high speed jet
Posted on Oct 24, 2008
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
  • 146 Answers
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 07, 2010
Cub cadet rzt 50 making grinding noise when starting after it starts still making noise sounds like coming from fly wheel. any suggestions thanks
The shaft that the solenoid pushes the gear up needs lubrication. If it's been grinding too long, the bearing in the starter is worn letting the armature to rub on the field frame. Might be time for a starter motor.
Oct 02, 2016 | Cub Cadet Garden
Cub cadet 10 50, briggs and Stratton, V twin cylinder, 2011 lawn tractor model 13wr91ap009 serial 1c030h60037. has spark and gas ad air but will not run. It almost idles but then quits.
Hi Lorraine:
If you take the air filter off and squirt in a bit of gas, will it run? If so, the carb is probably gummed up and a good cleaning should get it happening.
Jul 13, 2015 | Cub Cadet Garden
Idle pulley off a Montgomery ward 16-42 7 speed will work on a club cadet mower
You need to spec it out to know if will. Diameter, Height, offset, and if it V groove or Flat. In most cases they don't swap out that easily as Cub Cadet (MTD) products are usually very picky about these things just like their belt sizes.
Jan 29, 2015 | Garden
My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
Apr 17, 2013 | Garden
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
46 inch cub cadet mowing deck need diagram for belt
Go to... http://www.partstree.com/parts/ Click on the Cub Cadet logo then enter your model number. All the diagrams are there.
Jun 11, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
REMOVE PARKING BRAKE ENGINE STALLS
i have a cub cadet 2130 2000 seris but it quits when i rekwase the brake pedal
May 03, 2009 | Oregon Scientific Oregon Gator Mulcher...
Garden Logo
73 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
