Question about Refrigerators
Ge profile pds22sbrbrss
Changed main board, fan running but compressor won't run
Milleniumboy
  • 106 Answers
SOURCE: Refrigerator and freezer stopped making cold over night, its a GE
Try to check for Warranty protection, and if the time coverage has not yet elapsed. If it has not, try to take to service technician, if it has, then the problem is just the Coolant, a chemical liquid that when its volume is expanded, its temperature drastically drops, its called freon. Try see if you can replace the coolant. :)
Posted on Apr 26, 2009
SOURCE: Ge Monogram ZISS420DMAS compressor and fan not running
ICE CREAM WON'T FREEZE
The ice cream does not freeze, it stays soft. I have a GE Monogram 42" Built-in-Side-by-Side Refrigerator.
Posted on Jun 18, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE profile TFHW22R side-by-side fridge compressor issue
Most times replacing the start relay part=> WR07X1001 start capacitor=> WR62X80 and overload=> WR8X97 will resolve the problem. Click here to downlod the Service Manual=>PROFILE ARTICA SERVICE MANUAL CLICK HERE and go to this page to use he Tech Sheet> GE Artica Profile Technical Information If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Posted on Jan 26, 2010
Testimonial: "Great response time. Very helpful too."
marka19
  • 1430 Answers
SOURCE: My compressor cooling fan quit- the compressor
The problem is most likely the condensor fan motor is starting to fail. This is easy to check, First remove the back cover and when the compressor is running you should have voltage going to the fan motor if you do the fan motor needs replacing if not then the main board would be at fault here is a link that should help http://appliancehelponline.com/refercondenserfan.html
Posted on Jun 23, 2010
Macmarkus
  • 2605 Answers
SOURCE: GE Profile fridge: freezer is
Hello, welcome to FixYa.
I understand based on your post you have a GE profile PFS22MIS fridge not cooling in the fridge (upper cabinet) section, correct ?.
It is possible the problem is related to the condensor fan, but not likely. The difference with these fridges and many others (especially the older fridges) is the condensor fan does not run all the time. Instead the control board at the back (pcb) tells it when to run and at what rpm to run as well, it is a variable speed fan motor...and may in fact not run at all at periods.
The one thing I'd suggest you inspect is the back wall of the freezer. You mentioned the evaporator fan motor is operating, correct ? Is there any frost build up on the back wall of the freezer section, or if not visible have you removed the back wall of the freezer ?
I will need to watch for your reply before going forward. I hope you can appreciate there are so many variables since the fridge has many factors controlling air flow which in turn determine what the possible problem and solution will be.
Sounds to me it is a damper or blocked evaporator initially at least. Let me know what you find and we'll go from there.
Regards,
Macmarkus :)
Posted on Sep 20, 2011
The interior lights don't work in my ge profile refrigerator and the refrigerator will not cool, the main control board has just been replaced. what else could it be?
The replacement board could be defective but also the board could have been replaced when, in fact, the problem was caused by something else.
Feb 23, 2018 | GE Refrigerators
GE model Pfs22miwww. Condenser fan and compressor not running. Tested start cal it is ok. Changed ontology board. Condenser fan now running. Still no compressor
Have you changed out the WR55X10942 Motherboard? Here is a link to test points on the motherboard HERE and here is a service manual HERE I don't mind helping answer your questions so feel free to contact me, Thanks Sea Breeze
WR55X10942 Main Control Board
Mar 22, 2013 | GE G.e Refrigerator Wr55x10942 Motherboard...
My ge profile refrigerator evaporator fan motor stops while the compressor is running
this is normal as if one compartment is cold enough but not the other compartment the sealed system has a valve in the refrigerant circulation system to channel the refrigerant flow to the compartment that is calling for cooling so that fan will cease operation in the compartment thats cool enough
Dec 14, 2012 | GE Profile Stainless Bottom-Freezer...
GE side by side fridge HSS25IFMDWW burnt pin on relay on main board and compressor not running. Tested compressor and it runs okay. What would cause the burnt pin?
Most times the motherboard is the problem that causes the solder to melt from a defective relay. You will need to inspect the compressor start relay and capacitor to insure that they did not cause the relay on the board to overheat. Also check that you have 12 volts dc going to the evaporator and condenser fans while running because if for some reason the fans are defective and you change the motherboard while one of the fan motors are defective your new motherboard again can be damaged. Here is a link to a=> Artica/Profile Service Manual
Here is a motherboard test photo=> Artica Profile Tech Sheet I will be glad to help answer any questions you may have Thanks Sea Breeze
Aug 28, 2012 | GE Refrigerators
GE profile freezer and fridge not cooling
this unit has a control board on it ...the first few things you need to check if the unit is still plugged in... do you have any frostg build up on back wall inside freezer... if you do it tells me compressor is still running and most likely you have a defrost issue either the heater,defrost thermost or the defrost board is bad.... if no frost build up you need to gain access to the rear of unit is the compressor coming on should be able to here it or put your hand on it and it will be hot...
if not running you could have a bad thermostat or the actually main control board has failed.. if it is running check all your fans inside freezer and down by compressor are they working... hope this helps repost with more info
Mar 12, 2011 | GE Profile PSW26P Stainless Steel Side by...
GE profile Refrigerator Model # PFS2251SBSS
You must be referring to the compressor. It's possible it could be your main control board on the back of the unit. Typically its these main boards that go out, as they control everything on your GE Refrig, pretty much. If its not the board, it could be your Relay on the compressor, or the compressor its self, however, in my experience, GE's compressors are pretty decent.
Mar 28, 2010 | GE Refrigerators
G.E. profile mod. # PSS26SGRB SS not cooling
Check to see if the compressor is running. If it is not running take note if the fan beside it is running. If it is the main board is most likely bad. Remove the main board and check for burnt solder joints. If you are familiar with soldering you can fix any bad solder joints and your refrigerator may go back to work. This page will help http://www.appliance-repair-it.com/GErefrigeratorrepair.html
Sep 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
