Question about Amana 7M11TA Air Conditioner
WIndow air conditioning unit blowing black particles every time
Why does this happen every time the unit is turned on?
  • 102 Answers
Maybe the filter needs to be cleaned?
Posted on Jun 22, 2009
Air conditioning unit blowing warmer air even when unit is set on 70 and then will blow for 10-15 minutes and then cut off for 5-10 minutes before coming back on again blowing warm air.
If its a window unit, pull out of window get to the front fins might have to remove a few screws on the sides of front and spray out with a hose be careful not to get control box wet.spray fins and wheel inside, dump water out the back or side, put back in window it should start blowing cold air if not then its time for a new one.but sounds like its getting over heated
Aug 28, 2017 | Heating & Cooling
Unit on but then iys shutting down
Can you please more setails in to what your unit is doing. Does the main start up screen come on then the tv turns off? Does it make a clicking noise? Does this happen every time you try to turn your unit on?
Jul 24, 2013 | Televison & Video
Goodman Heat Pump laing heat and loud noise
Taking a little bit of time for heat is normal but the "pressure" thing you are referring to leads me to believe that the reversing valve is getting stuck. You will here that "pressure release" noise with a reversing valve but it should not be happening 5 minutes after start up.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 06, 2017 | Goodman Heating & Cooling
Keeps blowing 3 amp fuses when i turn the air conditioning on.
Ok, If 3 amp fuse is blowing in the air handler unit when switch is turned to cool check to see if outside unit jump starts and stops when this happens. If this is the case wiring is fine check main relay in outdoor unit. There will be a spring contact on main relay (Black relay close to where wires come into unit), check for corrosion or carbon build-up on little round contacts. If you can clean contacts with a small piece of sand paper. Make sure all breakers are off before removing cover! You might have to remove relay in order to clean it. Make sure you write down exact locations of any wires you remove. This should fix the problem.
Jun 20, 2012 | Heating & Cooling
I already sent in a question Order # 29744. Our window air conditioner Frigididaire Gallery blows out black particles about 1/8-1/4 inch in size. What is it? Is it dangerous? Please answer immediately. ...
Probably, what you're seeing is rust from the drain pan under the unit, that has become dislodged and is being picked up by the AC unit's fan or it could be the air intake filter breaking down and being blown in the house. Have you removed and inspected the air intake filter for dirt or clogs or deterioration ?
These are the things you need to inspect and troubleshoot first, to determine where they are coming from. If the unit is continuing to cool, as it should, I suspect that what I mentioned above may be the cause of the particles.
If it's the air intake filter replace it. If the particles appear to be rusty or slick, try flushing the drain pan under the outside of the unit. Be sure the outside of the unit is tiled down at least 1/4". Or it will not drain properly.
Is this a dangerous situation? I don't feel comfortable saying "Yes" or "No". But, it has to be a messy one. Be sure to turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to troubleshoot anything.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks
Jun 20, 2011 | Heating & Cooling
Had the unit (46UX600U) for about 8 months with no problems. In the last couple of days the unit will seem to turn itself off and then back on. The green light never goes off though. This happened once...
If going through a cable box you may be loosing signal from time to time. Try playing a DVD to rule out the possibility that its your tv. Try replacing cable box, or add a cable amplifier. Hope this helps.
May 13, 2011 | Toshiba 46UX600U TV
PS1210 suddenly won't turn on. When I unplug and plug back in, all the lights flash three times, then everything turns off.
I have had this happen on several units and there is not a way to fix this. It is showing an assert error and the printer is at the end of its life. Time for a replacement unit.
Feb 02, 2011 | HP PSC 1210 All-In-One InkJet Printer
What does E1 mean this comes on when the air conditioner turns off
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Sep 30, 2010 | Sharp Heating & Cooling
My airconditioner displays E1 and turns off after only 3 minutes of use, what's happening?
heatman101
Sep 03, 2010 | Sharp Comfort Touch AF-R120EX Air...
Amana 7M11TA Air Conditioner Logo
362 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
