Question about Yamaha Televison & Video
My yamaha dvd s5450 opend drawer and put up a blocked sign on disply, I can open it and close it it wont load up cd it just keep saying blocked.
SOURCE: dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Posted on May 01, 2008
fieldy14
  • 456 Answers
SOURCE: LG DVD recorder/VCR Combo problems
you need to replace the dvd loader(the whole setup, the draw/tray,laser sled assy ,etc) statewide sell
parts for lg.unless you know an authorised lg repair agent.too bad you dont know me, lol.
(ps,its not in the manual,cuz there is nothing you can really do about it without serviceing the unit)
Posted on Oct 10, 2008
  • 3 Answers
SOURCE: ge 1101 pa dvd player keeps saying no disc
Try turning the disc over.
Posted on Dec 25, 2008
coyotet60
  • 5 Answers
SOURCE: Koss KD365 DVD - Says No Disc
Make sure the disc is spinning. This might sound crazy but try turning the whole player upside down and see if it plays.
Posted on Jan 01, 2009
SOURCE: Drawer won't open. Says "blocked".
I had the same problem with a comparable device. It turned out that the drive belt that operates the ejection mechanism wears out or breaks.
To get at it you need to do the following:
1. remove device cover
2. remove the identification cover on the front of the DVD tray. This may be tricky if you can't open the tray. You need to find a way, because otherwise you can't remove the DVD unit, at least not on my unit.
3. remove the DVD unit by detaching the cables and removing four screws.
4. remove the two top screws on the DVD unit
5. remove the front top cover of the DVD unit by pushing the two tabs on the top of the unit, near the front.
6. Now remove the tray, by pulling it out as far as it goes and then pressing two tabs on either side of the tray. These tabs look like this:
7. Now you get at the drive belt. Originally it was black; I replaced it (temporarily) with a red one in the picture below:
8. Now put everything back together.
Posted on Aug 21, 2009
Dvd tray won't open. Says blocked then open & close but nothing is happening. It's making a noise & the dvd loading sign is continously on the tv
hello. I've had the same problem...I resolved it leaving some cd or dvd inside for ever.
To put into a dvd, look at the picture and the service manual
http://www.zshare.net/download/824070401c355e7d/
Jun 10, 2010 | Philips DVDR3455H/37B
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
Cant get cd to work keeps saying loading goes no
Since the details of your problem description is sparse, I presume you are trying to load a DVD - not a CD - to watch on your TV. If in fact you ARE trying to watch a CD on your TV - won't work! A CD can be viewed on your computer, but not the TV. They are not interchangeable.
If however you are trying to load a DVD, the disk may me dirty or damaged. Check that the back of the DVD is free from finger prints, marks, or deep scratches. If it is, you may be having some issues with your DVD player. I sometimes have a similar problem that can be resolved only by opening and closing the drawer of the player several times.
Nov 19, 2009 | Goodmans W280NS Television
Dvd drawer wont stay closed
take it back to the store or repair shop. Same thing happened to a friend and because it was new, the machine was exchanged.
Jan 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
BLOCKED MESSAGE ON YAMAHA DV-S5450 DVD PLAYER
The DV-S5450 may use a belt-loading mechanism. The belt is typically black rubber band with a diameter of approximately 2 cm. It is commonly found in front-loading CDROMs for computers also. Often, as a result of age, usage, humidity, etc the belt snaps, rendering the loading impossible. The loading motor doesn't just pop the tray in or out. It also engages a clutch assembly that raises an inserted disk or lowers a disk to be ejected; this explains why you can't simply force out the tray. Clearly in your case all the electronic signals are there and the loading motor does turn.
Solution: switch off and unplug the unit and then open it up. Do a quick inspection to see if you can locate the broken rubber band. If you can, remove it and take it along with you to the nearest repair shop for exact replacement. If you are finicky around technical work, simply a competent person do it for you. Good luck.
Jan 18, 2008 | Yamaha DV-S5450 DVD Player
Dvd player
Jan 14, 2008 | Televison & Video
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
"BLOCKED" message
Solution 1: Most likely there is a foreign mechanical object obstructing the tray mechanism. If, like me, you have kids around every corner then most likely a curious little one has pushed something in to see "just what will happen". With some luck you can solve the problem by opening up the unit (power-off, unplugging first, of course) and doing a visual inspection for what shouldn't be there (pieces of paper, coins, toothpicks, fibres, etc).
Alternative Solution 2: Sometimes what happens is that the tray loading belt slackens over the years (age, humidity, over usage) and fails to respond quickly enough. In the absence of any obvious foreign object(s) this is a likely alternative explanation. Drive-tray electronics (called SERVOS) are programmed to expect timing signals to come within well-defined intervals of time. If this does not happen (such as due to a slack belt), then the condition is registered as an error. Try replacing the belt if solution 1 does not work.
Sep 26, 2007 | Yamaha DV-S5450 DVD Player
Televison & Video Logo
19 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
