Question about Boss Audio MCK1308WB.6 Package w/MR1308UAB Bluetooth Receiver, 2
Marine stereo Have power but it won't come on
JVC Marine Stereo wont power up
I agree with kenw392. I tried to post a solution earlier from my phone but it kept telling me I had illegal characters in my post, which is silly, because they were all normal letters.
Apr 17, 2014 | JVC AM FM CD DET FACE CAR STEREO
Mb quart marine stereo fuse issues WR 1-CD
There might be some shorted component/s on the circuit board. Seek tech support.
Jun 02, 2012 | MB Quart ALX80IW Main / Stereo Speaker
CDX-M20 marine stereo problem
Same problem here. Do you recall what you did to bring up the display?
Apr 20, 2012 | Sony Cdx-m20 Marine In-dash Boat Stereo...
My receiver in my boat does not respond to any of the modes. Even the power switch does not turn off the unit. I have to cut the power to turn off the device. Any ideas?
You are using a non marine radio unit in a marine enviroment.
I am going to go out on a limb here and say that the electronics are corroded and causing a short in the unit.
Aug 21, 2011 | JVC AM FM CD DET FACE CAR STEREO
I have a jbl mr-145 in a hot tub. It keeps powering on and off???
I have the same model stereo in a brand new hot tub that was having the same issue. To fix it all u need to do is pull the front cover off to access the pump controls and in there you will find a black box where a power cable runs yo the stereo. There are two screws that open a little door in the black box. In there you will need a small flat head screwdriver to move a redswit over to the 110 volts position. Turn the radio on and it should work. That black box just controls the power to the stereo.
Oct 09, 2010 | JBL Marine Audio Wired Remote
My JBL Marine Hot tub Sterio quit working suddenly?
JBL is at best a low quality marine grade brand of stereo. It is now garbage. I have worked on hot tub stereos for many years, PolyPlannar is the only one that is any good. If it was bought 30 days ago, where's your warranty?
May 31, 2010 | JBL Am/Fm/Cd 180 Watt Marine Audio System
I need a MP3 adapter for a Pioneer Super Tuner D marine Stereo
Thanks for using Fixya.
You can buy the mp3 adaptor for your Pioneer Super Tuner D marine Stereo from this link.
Please accept the solution if your problem is solved.
good Luck and have a nice day
Apr 27, 2010 | Pioneer Car Audio & Video
No power
Do you have the manual. I have the same model installed on my BMW 1100RT motorcycle and it requires two power hookups. One senses the ignition is turned on and the other is the power up from power source. If the ignition power wire isn't connected, the unit will not powerup. You can however, connect both of these power wires to bypass the ignition switch. This ignition switch is used so you don't kill your batter by accident. I'm sure that wouldn't be good on a boat. Good luck!
Mar 03, 2009 | Car Audio & Video
Is this considered clipping in marine boat stereo help!!!!
if your radio is puiing more power your ground might not be good enough, use the same spot but remove the ground and rough it up a little on the base with some sand paper or add a metal o ring to get a better ground.
Jul 30, 2007 | iLO XM-MP3-CD Car Stereo
Boss Audio MCK1308WB.6 Package w/MR1308UAB Bluetooth Receiver, 2 Logo
83 people viewed this question
Top Boss Event Planning & Celebration Experts
DAVE PARTA
Level 1 Expert
gamehouse8888
Level 1 Expert
 steve
steve
Are you a Boss Event Planning and Celebration Expert? Answer questions, earn points and help others
