Question about Brother LS-2125 Mechanical Sewing Machine
How to replace feed dogs on brother ls2125
My feed dogs are worn and cannot get to the screw to put new one in.
SOURCE: Feed Dog on Brother 270d stuck in up position
I finally figured this out. The feed dog switch in the back was not hitting anything when I moved it back and forth. There is a screw on the underside of the machine that I tightened. It seemed to do the trick. Thanks.
Posted on Jan 15, 2009
bargainbox
  • 1388 Answers
SOURCE: Brother Super Galaxie 2100 - Feed dogs will not lift
Remove needleplate and clean out the built up lint between the teeth of the feeddogs.
When moveng from Feed Down to Up, rotate handwheel one revolution to re-engage.
If neither is a problem and your manual is of no assistance, take it to a service centre to check it out and quote.
Posted on Aug 19, 2009
  • 152 Answers
SOURCE: my feed dogs will not come up into position
Some machines have to take a stitch for the mechanism to "pop" back into place, I don't really know if your brother is like that but try to sew with it and see if they click back into place.
Posted on Oct 23, 2009
  • 1788 Answers
SOURCE: I bought brother 5000
have you turned the handwheel at least 2 revolutions toward you after to put the feed dogs up?
Posted on Oct 15, 2010
SOURCE: I lost the Buttonhole fine-adjustment screw for
I just wanted to share my situation with you. I had the same problem. When I tried to use my Buttonhole fine-adjustment screw, it broke up and fell inside the machine. My husband opened the machine to get the broken parts out (two of them: first one - white-colored plastic broken part of the adjustment screw and a metal, half-moon shaped washer).
I called 1-877-276-8437 (BROTHER), and the person who checked the list of replacement parts said to me that this particular screw was not in the list. So that person gave me the number of the closest service center where I called.
The service person told me that it was no cost to see what was the problem, but to determine how much the solution would cost he needed to see the machine. I asked about the minimal cost of a service; it was $89+ the cost of the parts. It means the minimal cost of the repair (without the price of the replacement part) goes 14 dollars beyond the price of a new machine, which in Amazon.com today 10/2011 is $75 for the same model LS-2125(i).
My solution was to get out the broken part for which my husband unscrewed for me the front plastic shell and took out the two little broken parts. During this procedure, he realized I could use a narrow scissors to make the remaining part of the Buttonhole fine-adjustment screw turn around. This way I can still use my machine with no need of buying a new one.
Posted on Oct 27, 2011
I have a brother ls 2020 and it will not feed fabric through. I am thinking my feed dogs are messed up but i don't see anything about lowering or raising them. Will I have to take it apart?
According to the manual, your machine does not have the capability to drop/raise the feed dogs. Instead, there is a cover plate that is installed over the feed dogs when performing darning or free motion quilting.
Check that your stitch length is set high enough to actually move the fabric. Some machines also have a presser foot pressure adjustment that will increase or decrease the amount of pressure the presser foot applies to the fabric and the feed dogs. If your machine has this adjustment, it may help to increase the pressure so the fabric will move better. Another thing to check is whether you are using the correct presser foot that will actually rest on the feed dogs.
Reading the hints on pages 28 and 29 may be helpful.
User Guide Manuals LS 2020 Others Brother
Another possibility is that the feed dog points have been worn off. When the points are worn, they no longer grip the fabric like when new. When stitching, be sure to never run the machine with the presser foot setting directly on the feed dogs, it without fabric.
Jan 05, 2018 | Brother Sewing Machines
How do I raise the feed dogs in a Brother LS2125 sewing machine as they seem to be lowered?
Perhaps you will find the answer here:
LS 2125 2125i 2129 United States Brother Solutions Center
FWIW, the manual indicates that your feed dogs do not lower. Instead, you are provided with an accessory that covers the feed dogs when you wish to use the machine without feed dogs.
Jan 15, 2017 | Brother LS-2125 Mechanical Sewing Machine
How can i do free motikn quilting with my machine
On page 35 of your manual (see link below), there are instructions for darning. It looks like your machine needs to have the darning plate installed over the feed dogs before you can perform darning or free motion quilting. If you do not have the darning plate, then you will need to get one.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=0CFAQFjAH&url=http%3A%2F%2Fecx.images-amazon.com%2Fimages%2FI%2FB1dzfyluFLS.pdf&ei=jkMpVYmGFsWzoQTryICoCA&usg=AFQjCNEBTgKmXv2EyHiiw-px33CFogPHXA&bvm=bv.90491159,d.cGU
Mar 14, 2015 | Brother LS2125 SEWING MACHINE. D/B
Thread jam bent needle feeddogs went to down postion and i can't get them to come up
Ok, your going to need to get a new needle. If you can, snip the thread jam to get it out. If the needle is stuck, trying loosening the screw(or whatever) holding it in. This is typically a tension problem I find, but as for feed dogs, did you forget to put the presser foot down? Also check the settings on your machine, mine has a switch to not use feed dogs.
Dec 07, 2013 | Brother Sewing Machines
How do I adjust the feed dogs on the brother LS-2125?
Do you have the darning plate over your feed dogs? Read your manual, to see what the problem is. If, you do not have a manual go to www.brother-usa.com under support and download your manual for free, when you enter your model number-LS2125
Sep 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
How to drop the feet on a brother ls2125 sewing machine
Not sure what you mean.
If you are referring to the feed dogs - they do not drop or disengage.
Instead, there is a cover that is used - part # XA3442-121
If you do not have a manual, you can download (free) at the Brother website.
Mar 04, 2010 | Brother LS-2125 Mechanical Sewing Machine
My feed dogs will not come up into position
Oct 22, 2009 | Brother Sewing Machines
Feed dogs are down
You might have the machine on a setting that does not use the feed dog. Check your stitch setting and see if that helps.
Dec 12, 2008 | Brother XL-2610
Brother LS-2125 Mechanical Sewing Machine Logo
26 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
