Question about Cell Phones
How do you replace a belt on an ABDICK 360 off set printer?
Loose or worn drive belt on the y axis assembly for a phaser 360
I don't believe parts are available for that model anymore...It is amazing it has lasted this long !
Sep 28, 2013 | Xerox Phaser 360 Thermal Printer
Printer says Drum Error
Then the drum (which the toner sets in) most likely needs to be replaced, if you have not replaced it recently. They are only good for so many copies and wear out. Should be DR-360.
Jan 14, 2013 | Brother MFC-7340 All-In-One Laser Printer
How to change a timing belt on 2003 ferrari 360 spider
The 360 has an access panel behind the seats. To get to the panel the interior trim behind the seats has to be entirely removed. Assuming that you have changed belts before, as an interference engine with tight tolerances, you can not be off one notch without destroying the engine.
the tensioner pulleys should be replaced with the belts. you can spin the bearings to check them but after all the work getting there I would replace them. tension is set through eccentrics.
Dec 01, 2010 | 2003 Ferrari 348 Spider
I have replaced timing belt and head gasket after having a blown head gasket set tdc and all timing marks but motor backfires and almost starts but will not please help me
Sounds like the timing is 180 degrees out. You would have to unhook the belt and turn the crank 360 degrees and put the belt back on. I hope this helps!
Sep 14, 2010 | 1990 Honda Accord
Lexmark X500N says replace transfer belt, what is it, and how do I change it?
The transfer belt is located inisde the printer and is what moves the paper back out the printer. You will need to open the back cover of the unit then you will lift the top part of the printer off. This will expose the transfer belt. There is a bracket holding the transfer belt with two screws that will need to be removed. Then two more screws that are holding the belt assembly in place. Once those are removed then you can slide out the transfer belt assembly. The new replacement transfer belt assembly will slide back in replacing the old one. Then repeat the steps opposite to install. Then remove the four spacers on the new belt(on each corner). Then you will reset the counter for the belt and will need to run the printer alignment settings.
Nov 13, 2009 | Lexmark X500n Color Laser All-in-One...
I switched my 360's disk drive wont recongnize the game disk
This is more than likely your laser that is dead and its possibly a samsung or hitatchi drive, be careful when buying a new laser because there is a lot of dodgy ones around at the minute which can damage your machine or at the very least will be inferior and not last long.
It could also be the logic board or the drive belt too, if the logic board is faulty no matter how many lasers you try it will do the same, the fix is to replace the logic board.
if its the drive belt well this is very easy to try and is what id try first, open your 360 tray and look inside the 360 you should be able to see the drive belt, make sure its attached properly and then take this out. replace it with a new one and see if this recifies your problems.
SOMETIMES if a drive belt is stretched it will not close properly and then a fault like yours will occur. its all a matter of eliminations. Drive belts can be found on ebay.
www.XboxRepairKit.co.uk
Sep 24, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
Replace belt CG
Set Belt CG The OPC belt cartridge needs replacement.
Replacing the Optical Photoconductor (OPC)
Belt Cartridge
Replace the OPC belt cartridge at least once every 12 months, or when
the control panel display indicates that replacement is necessary. The life
of the OPC belt cartridge for the T8106 is about 60,000 images (15,000
color pages), at a 5% toner coverage rate on letter-size paper.
1. Turn the power switch off.
2. Unlock the lever to open the front
cover. This releases the pressure on the
toner cartridges.
3. Unlock the lever to open the top cover
fully.
4. Pull the green OPC belt cartridge lock
levers up until they unlock.
5. Pull the used OPC belt cartridge
upward and out of the printer carefully
to avoid spilling toner.
6. Discard the used OPC belt cartridge
Caution! Do not touch or wipe off any powder that is on the OPC belt, nor expose
the OPC belt to light.
7. Remove the two shipping pins from the
new OPC belt cartridge.
8. Remove the protective sheet that covers
the photosensitive belt.
9. Slide the new OPC belt cartridge downward
into both green lock-lever guides
and into the printer carefully.
10. Push the green OPC belt cartridge lock
levers down until they lock.
11. Close the top and front covers carefully
until they both lock.
May 28, 2009 | Tally T8106 Laser Printer
Tally Genicom 8008
The Set Belt CG message on the 8008 indicates the printer is not detecting the OPC belt (the green reflective belt located in the top of the printer)
Try removing the Belt Cartridge and relocate this in the pritner, if this fails to fix the problem remove the Belt Cartridge from the printer then look down one side of the belt- (I think the left side of the belt), for black squares (I think there are two) the printer uses these to detect the Belt Cartridge is rotating. Check for damage to the Belt in this area. If the printer does not detect the belt as rotating it will indicate this error.
If the Belt Cartridge looks ok, remove the Belt Cartridge from the printer then look down the hole left in the printer when the belt cartridge is removed. Look for any obstuctions, also look at the black belt which is towards the back of the printer when you look in the top ( the transfer belt, I think) Look to see if there is any damage to this it may cause the Set Belt CG message.
Apr 02, 2008 | TallyGenicom 8008 Laser Printer
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
