Question about RCA 7 DUAL TABLET DVD SYSTEM
How to charge rca tablet with USB Port? - RCA 7 DUAL TABLET DVD SYSTEM
How do i transfer music off a flash drive onto my RCA 10.1 Android tablet
tablets use the charge port as a usb extension
try using a usb connector from the usb stick plugged into the charge port
Sep 17, 2016 | Tablets & eReaders
Battery port
Depending on how hot you may be right. It is normal for the battery to heat up when you charge it. I have an RCA tablet that while the charge port (which doubles as the micro USB) fits tight and the battery still heats up to the point where it is hot to the touch but not to hot to hold. If your charging port is broken then the tablet will nont charge at all. If it is loose and not getting good connection then the battery will charge intermittently. Again either of these issues will not cause the battery to get abnormally hot. However, if there is an issue with the battery itself then it may get too hot. If so the charging circuit thermistor should cause the battery to stop charging.
Aug 24, 2016 | Tablets & eReaders
If the charging port for my zeiko 10 inch is broken,what other way can I charge
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Jul 11, 2016 | Tablets & eReaders
Is it ok to charge my RCA tablet pc w/a micro mini USB?
if the micro mini usb port fits the tablet ---yes as that is the cable used to charge it with
Dec 21, 2015 | Tablets & eReaders
How can I fix the RCA 7in power port?
You should contact Authorized Dealer or Service Center to get it serviced.
Apr 26, 2014 | Tablets & eReaders
Replace RCA 7in power port?
Contact any service technician. The set shlould be opened to replace it. It can be replaced. Gopakumar Gopalan Google
Apr 26, 2014 | Dell Streak 7 Tablet Android
Charger broken
Go to ebay, type in the exact model of your tablet and search for the tablet, you can order one from there.
Feb 10, 2014 | RCA Ipod Tabletop Charger With Usb Port...
RCA 7 DUAL TABLET DVD SYSTEM Logo
22 people viewed this question
Top RCA Tablets & eReaders Experts
ka4iup
ka4iup
downhille
Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
