Question about Onkyo TX-SR304 Receiver
Where do you connect an emitter on a Onkyo DX-C390
2 Suggested Answers
mlapres
  • 757 Answers
SOURCE: I have a onkyo tx sr304 and a onkyo 6 disc player
The only possibility that comes to mind is that it may be causing a short somehow when the carousel gets to that position, maybe a broken solder joint. Another possibility is that there may be a foreign object stuck inside the player such as another disc that lost it's position.
Posted on Feb 25, 2010
Onkyo DX-C390 with Denon AVR-S710W? This doesn't seem to work when input to the amplifier's media player audio inputs. Do I need a preamp?
Both of the devices have optical connections, by getting a lead between the two you should hear the high quality sound from the unit. Make certain the optical connection is switched on and assigned to the Onkyo.
Only a record player requires a pre-amp. If it the amp doesn't have a dedicated socket for it.
Jul 04, 2017 | Denon Audio Players & Recorders
How do I recover CDs which disappear inside the Onkyo DX-C390 ?
The manual has little info. I'd try unplugging it for 5 minutes or so. If that doesn't work, I'd try holding the eject button in and hold it while you turn it on.
May 25, 2017 | Onkyo Audio Players & Recorders
ONKYO CD DX-C390 6 CD CHANGER NOT READING
No laser, means no laser. Typical symptom of laser failure. Most CD players can have the laser replaced fairly easily and cheaply.
Contact your local technician, and he should be able to replace it quickly.
Oct 30, 2014 | Audio Players & Recorders
Onkyo DX C330 carousel goes in and out without stopping and won't quit spinning around
Sometimes the tray ribbon goes bad causing bad connection to main board! Common
problem with alot of brands!
Apr 22, 2011 | Onkyo DX-C390 6-Disc CD Changer
The stand by light is on and the machine is not working
Do not buy Onkyo. Quality is VERY poor and tech support even worse.
Feb 21, 2011 | Onkyo DX-C390 6-Disc CD Changer
Onkyo DX-703 CD tray engine tries to oepn but cannot when I put CD player on and hit open. What can I do?
You're tray may be opened with a belt, maybe it's slipping over the plastic wheel.
Good luck,
Gerard
Jan 14, 2010 | Onkyo DX-C390 6-Disc CD Changer
I can't turn on the unit.
no on/off switch on this model; use the remote or load it and press play AFTER you plug it in............
Jun 06, 2009 | Onkyo DX-C390 6-Disc CD Changer
Onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
May 07, 2008 | Onkyo DX-C390 6-Disc CD Changer
DX-C390 turn on
Use a surge protection power strip (such as the Power Protect AV 600 by Monster Power).
This will elliminate erratic behaviour of the unit, since even minute fluctuations in the power source from unbridled house current will affect the sensitive internal components of the Onkyo DX-C390 6-Disc CD Changer.
Dec 07, 2007 | Onkyo DX-C390 6-Disc CD Changer
Onkyo TX-SR304 Receiver Logo
13 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
