Question about Konica Minolta DiALTA Di200 Copier
Operation mode di5510 - Konica Minolta DiALTA Di200 Copier
  • Konica Minolta Master
  • 6,168 Answers
Adimin mode or service mode?????
Posted on Dec 30, 2015
Error code sc36-03 ?
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". close out to original screen and power off the machine. wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Feb 15, 2015 | Konica Minolta Minolta Dialta Di5510 Laser...
How i change the developper of konica di5510 plus the code of it
I would recommended you get a konicaminolta tech to that it not simple in will require developer, knowing the service mode 36. Clearing counters in mode 25. Try a web site that sell the old Konica Minolta service manual. follow step by step.
Feb 04, 2015 | Konica Minolta Minolta Dialta Di5510 Laser...
Konica minolta bizhub Di5510 driver for windos 8
You can try konicaminolta web site drivers are free. But Di5510 I believe best you can do is XP or windows 95. But give the web site a try.
Sep 26, 2013 | Minolta bizhub 200 All-In-One Printer
I have a di5510 that keeps on hanging. the machine turns on fine, everything is perfect but then maybe after 2-4 hours the machine just gets stuck ...no error... any solutions or any diagnostics someone...
I would re load the firmware to the most up to date firmware . the other issue that causes this problem is the hdd hard drive i would rwplace the hard drive if the firmware does not fix the problem you can go into the tech rep mode carry out a physical and logical test this will prove if there is an issue with the hard drive
Feb 20, 2011 | Konica Minolta Office Equipment & Supplies
My customer has a bizhub di5510 copier that shuts down
If you can get schmatics diagrams of the machine locate which CB is breaking and then locate what units it feeds, such as fuser or HV ,LV supply boards etc Disconnect the board(s) assigned to that breaker see if it trips
Feb 28, 2010 | Konica Minolta Office Equipment & Supplies
Bizhub Di5510
SC49-01, SC49-02, or SC49-03 codes.
[Solution]
PROBABLE CAUSES:
1. Outdated firmware.
A flash ROM upgrade is available to correct this problem.
Notes:
a. See bulletin 3481A for details on this issue.
b. Make sure that the current version of system software (with applicable patches) is installed on the controller.
2. Improper shut down procedure of the controller.
Here is the correct shutdown procedure:
a. Shutdown the controller via the Di5510 control panel.
b. Turn off the sub switch (front switch) of the printer.
c. Turn off the main switch (rear switch) of the printer.
This procedure assures that the controller and printer are properly synchronized when power is applied. If the sub switch (front switch) is the only switch turned off, the Service Code will be generated the next time the printer is restarted.
Jan 03, 2008 | Office Equipment & Supplies
Konica Minolta DiALTA Di200 Copier Logo
26 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
