Question about Earthwise 1850 PSI Electric Pressure Washer
Earthwise 1850 motor quits after few seconds - Earthwise 1850 PSI Electric Pressure Washer
Why won't the hose connect to the washer?
The connection is made at the bottom of unit.
should be standard garden hose.
sometimes I find if I gently hold hose against connection point then rotate counterclockwise until I feel a click! then ( without lifting hose) rotate clockwise and hose should now be threaded onto power washer.
Oct 09, 2016 | Earthwise 1850 PSI Electric Pressure...
Where can I buy a rectifier for a 15 amp earthwise lawnmower
Hello Condo Sarto,
The first site that popped from an internet search...
Sears Parts...
searsparsdirect com
Jun 27, 2016 | Electric Earthwise Corded Lawn Mower...
Where can I get brushes for earthwise 6.5 pole chain saw
Any of the following could order them, or at least point you in the right direction to find them. Where to source them, I mean. Local chain saw repair place, small engine repair shop, electric motor repair shops, anybody who fixes electric motors or knows what you are talking about.?. This company must have a website, have you tried that?
I'm not one, but a typical Montanan ( state votes about 80% republican) would rather snidely comment, "Get that fishing pole out of here!" As a lone-wolf green, Progressive, sometime-democrat, I salute a company who recognizes "something" above profits. Nice name, earthwise. You may really have to contact the company and have them send you them brushes. I hope I have helped your day in some way. If not, I am chastened, and beg your forgiveness. As my dad, Earl, often said, "Do the right thing." That's how he lived his life, a true-blue Roosevelt Democrat, he loved to talk politics and slur republicans, from Eisenhower on to all the rest of them, but he personally liked Ike, voted for him. Saved his vitriol for Nixon and especially Reagan. He knew economics, and he knew reagonomics was a disaster for the USA. That is when the wealth inequality sky rocketed. Good bye, and god bless.
Jan 21, 2015 | Earthwise CVPS41008 - 8" 6.5-Amp Electric...
Replacing brushes on earthwise 8" pole saw
http://www.earthwiseproducts.co.uk/contact.php
Jun 26, 2014 | Earthwise PS40008 8" Corded Pole Saw
Earthwise battery charger flashes green then red then quits when plugged in
Typically that is an indication that the battery is bad. A battery supply place, such as Batteries Plus should be able to test the battery and tell you if it is good or not.
Mar 23, 2014 | Garden
HOw to attach soap bottle to earthwise 1850 pressure washer
It should have a tube on it put it in your bleach bottle and use the black tip for dispense 1/2 bleach/1/2 water
Aug 08, 2013 | Earthwise 1850 PSI Electric Pressure...
Mower started smoking, then stopped working.
Try to see if there is any oil in it. Or maybe your belt is clogged. A good cleaning and maybe a change of plug may help.
Mar 01, 2010 | Electric Earthwise Corded Lawn Mower...
The airconditioning fan runs for a few seconds then quits. The rear operates fine.
Sounds like your blower motor has quit if it is inop on all levels. If high speed works and the other speeds do not, then its probally the rheastat or resistor pack
May 05, 2009 | GMC Envoy XL Cars & Trucks
Earthwise 1850 PSI Electric Pressure Washer Logo
101 people viewed this question
Top Earthwise Garden Experts
Steve Sweetleaf
Steve Sweetleaf
 Larry
Larry
Call Bill
Call Bill
Are you an Earthwise Garden Expert? Answer questions, earn points and help others
