Question about Hitachi 50UX58K 50" Rear Projection Television
Shadows and not so bright picture
My Hitachi 50UX58K is now showing a shadow or ghost behind the images and the picture is not as bright as it used to be . HELP.
  • Hitachi Master
  • 3,459 Answers
Convergence is the problem. You can get instructions and parts frow www.TvRepairKits.com
Posted on Apr 18, 2010
There are shadows or ghosts in the picture
This is normally caused by bad grounds in the cabling. Check or replace the cable. Also check your manuals and be sure the cables don't have to be terminated
How to Fix LCD Monitor Ghost images
Aug 14, 2015 | Home Security
My picture was fine until i tried adjusting red and blue dynamics now i got the shadows in picture. how do i adjust it back.
Your convergence has failed and need to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed.
You can get the parts and instructions from www.TvRepairKits.com
Apr 24, 2011 | Hitachi 50UX58K 50" Rear Projection...
Model 50UX58K - picture has distortion & shadow on right side of screen
Hi, if the shadow is colored lines then you probably need the convergence ICs and possible reisitors near them replaced .
If the shadows is just like a ghost of the image or a bar from top to bottom, then check if it does it on every input (dvd for example) , there are blanking bars that you can't see past the edges of the picture and when you have a bad cable signal you can see the ghost of the blanking bar sometimes. if it does it does not show the shadow when watching a DVD then its a signal issue with your cable/satelitte .
If your convergence is the issue, try the adjustments first and if that doesn't correct it, you can replace the ICs using kit # x480293 or stk392-110 (2 ICs) soldered in very technical for even a technician.
repairman cost about $250-$350
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Sep 01, 2009 | Hitachi 50UX58K 50" Rear Projection...
Shadows/ghosting is present on screen at all times
What kind of shadowing are you seeing? Doe the picture look like a 3D movire (colors separated)? What is the make and model?
Please update this with the above info and I'll provide possible solutions.
Thanks,
Dan
Mar 20, 2009 | Televison & Video
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Green shadows all over the screen
You didn't say how old the set was and how much it's used, but the shadows you're describing sound like a bad green picture tube.
Hope that helps...
Geno
Apr 25, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Ghosts or shadows around images
I always start my Hitachi research at their website.........
www.HitachiServiceUSA.com...................T.
Nov 28, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue shadow or ghosting on screen
  1. First try Magic Focus
  2. if this will not fix problem
  3. then you have a convergence problem
  4. You will need the Converg. Kit
  5. X480295 part number
Nov 12, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hit 53UWX10BA
Check you cable box compared to another tv.  The pisture may need adjusting take off front panle and use the screws to adjust pic  it could get better of worst be carefull
Oct 21, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
90 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
