Question about ASUS VW193T Monitor
Why do i keep getting No DVI signal when I boot up my computer? Now the monitor has black screen
ASUS VE278Q monitor
    Top Expert:
  • ASUS Master
  • 14,162 Answers
HAVE THE MONITOR TESTED AT A LOCAL SHOP OR TRY ANOTHER MONITOR.
Posted on Oct 30, 2014
4 Suggested Answers
lserni
  • 466 Answers
SOURCE: My Asus PG221 monitor suffers from frequent issues
I'm afraid this looks like an electronic fault. Some component, most likely a capacitor, has degraded, is overheating and going out of spec.
You just might be able to squeeze some more hours of work - but the monitor is still likely to drop dead any moment now - by rigging a computer fan on the backside to extract hot air from the inside.
Possibly, the problem might have a noise factor - try adding a ferrite shielding on the cable (unless one is already there, as it often is) and see whether the thirty minutes' grace period extend somewhat.
A probably unsatisfactory solution might be to drive it at a lower resolution, so that the more relaxed frequency constraints do not stress the component so much.
When the capacitor finally blows, you might be able to recognize it and have it replaced; it's likely a US $1 component and is probably in the LCD driver section. Perhaps, just perhaps, you could already be able to see it with the naked eye looking for a component that looks "wrong" - a small cylinder that looks bloated, with electrolyte leaking, whitish powder around the base, etc. But you would still need some solder work to get it replaced - and, if it's a SMD component, chances are it can't be done at home.
Sorry for the bad news...
Posted on Oct 22, 2009
byteguy
  • 2229 Answers
SOURCE: when i start the computer and the monitor it says
How is the monitor hooked up? Are you using the SVGA plug (blue center with 15 pins) or the DVI (white with a lot of pins)?
Either way, if your monitor says there is no signal, then it means your computer is not putting out a video signal. Depending on you computer, this could mean 1)bad power supply 2)bad video card, 3)loose cable connection.
You'll need to check all three. Since the monitor does display a message, it is probably good.
Posted on Jun 17, 2010
SOURCE: why does my asus monitor always read "no signal".
nah that happens with me sometimes..
have you connect the cable properly?
if that still can't make it works, first turn on your PC and monitor..
then plug off the cable that power them, so that your computer and monitor will suddenly off..
plug it on again, then your monitor will work again..
that works on mine cause my CPU is too old and had a power problem..
Posted on May 07, 2011
Monitor on but getting no picture. The setting is DVI
Are you using a DVI cable to connect the monitor to the computer? Try changing the monitor setting to analog if not using a DVI cable.
Sep 07, 2014 | ASUS LCD Monitor
Problem with windows XP and ASUS VE278Q Monitor?
When getting consistant a line that is covering the entire screen vertical or horizontal in any width, is most likely due to a cable or monitor hardware defect.
1.
No matter what cable you are using, then make sure it hasn't been damaged - Sometimes a small dent cause a huge defect.
2.
Try a similar cable or the same cable in another monitor.
3.
NEW PRODUCTS:
Never wait or hesitate to contact the manufacturers support or the store where you bought the product to get a replacement or refund (warranty). Don't use a lot of time trying to repair something that should have worked and which you don't have any knowledge about, it is simply a waste of your time.
Jul 12, 2014 | ASUS LCD Monitor
How to adjust the controls on asus ve206 monitor in order
Most of these settings are done through a software panel - check this site for your specific ASUS monitor : http://www.service.asus.com/#!downloads/c1wax
Jun 11, 2014 | ASUSTeK COMPUTER Asus 20" Lcd Monitor Mpn:...
Cannot find power supply cable to Asus MS238H monitor.
You can use any Toshiba or Asus laptop adapter (19V 3.42A ) for this monitor.
Aug 13, 2012 | ASUS MS238H Monitor
I'd like my ve278q to turn on when my computer is turned on.
tried to replace bulging capacitor in the power supply module.
Jul 27, 2012 | ASUS VE278Q LCD TV
I have the VE278Q which is connected by display port, every time i turn off my computer and then turn it back on the monitor can't be found, I have to unplug the display port cable, unplug the monitor,...
when you say monitor can't be found did you mean the monitor has no reactions when you turn on your pc?
here are some test you may need to do to know which part is faulty
1. Turn on your computer, did it display the monitor's logo on screen? When it does monitor is good, when only blank screen it could be the vga cable or the video card.
2. See if the led indication lit. When it lit to steady green, it's good signal is coming in from the video card. It should be followed by screen display. If no display it could be the backlight inverter lamp busted or faulty inverter board. When lit green then turns red, no signal coming from the video card. Check vga cable if fix properly to both monitor and video card. Or may need to reseat properly connection of video card from the motherboard. If no led indication lamp, then monitor is dead. Check ac power cord for continuity using multitester. Check power supply section in the monitor, replaced bulged or blown capacitor with exact value, this components were the first to get affected when lcd monitor failed o turn on.
3. When computer was turned on got display and then monitor turns black, go check the vga cable, Fix the connection properly or may need to replace it with new one.
4. When no signal appears or display blank screen after logo, then check video card. First remedy is to disconnect it the reseat properly to the motherboard. If this have no effect change your video card.
go follow these steps and let me know which is closely to your problem so I can give you a good advise.
Jan 30, 2011 | ASUS LCD Monitor
Vw asus monitor
Download the correct driver for the VW193T monitor. Match your windows version.
http://www.asus.com/products.aspx?l1=10&l2=87&l3=545&l4=0&model=1686&modelmenu=1
Jan 03, 2009 | ASUS VW193T Monitor
Bought new monitor Asus VW193T help to find driver
change your resolution in display properties.
Dec 26, 2008 | ASUS VW193T Monitor
ASUS VW193T Monitor Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
