Question about 712T Keyless Entry 2-4but Rem Ob Relays Horne
I resently bought a new horn for my 95 pontiac grand am gt and after replacing the old one the horn does not work where is the relay and is there anything else I need to check?
  • 520 Answers
There is a relay bank under the dash and the lid will tell you which fuses and relays are located where. I would also check the fuse and the wiring. Good luck.
Posted on Jun 22, 2009
The horn in my 1999 Pontiac Grand Am GT dues not wrok how do i fix it and get to it thank you Michelle
check the relay and fuse first. it is in underhood fuse box on drivers side. the fuse is # 43 and its a mini fuse. the relay is # 21 and its a micro relay. to access horn remove right front headlight housing. on top of headlight housing there are 2 plastic slide pins. just pull them up to release housing. then look down to horn. when putting housing back on just push in on housing and push pins back down. have a good one !!
Feb 25, 2011 | Pontiac Grand Am Cars & Trucks
The horn in out 1998 pontiac grand am wont work. went and got a new horn and put them on but they dont work. fuse is good. someone said that it could be the relay. where is that located?
Actually the horn relay on this one is in the dash next to the flasher. This is to the left of the steering column if you are sitting in the driver's seat. It's kind of behind the dimmer switch.
Oct 03, 2010 | 1998 Pontiac Grand Am
Pontiac Grand Prix horn does not work. What is the best way to troubleshoot?
First, always check fuse.
2. If good, use test light at horn with button pressed to see if horn is getting voltage. If yes, replace horn.
3. If no, trace your way back--find horn relay in engine compartment fusebox and listen to see if it clicks when button is pushed. If yes, the wire from the relay to the horn is bad.
4. If no, remove the relay and test the socket for command signal from the horn button. See my tip at http://www.fixya.com/cars/r6022358-relay_check for how to check relay socket. If command signal is present, replace relay.
5. If not, the problem is with the wiring from the horn button to the relay.
Please let me know if you have questions
Sep 20, 2010 | 2004 Pontiac Grand Prix
The horn on my 2004 Grand Am gradually stopped working. (When using the remote to lock the doors, sometimes the horn would barely bleat, at other times it sounded fine.) Fuses and connections seem ok....
no, sounds like its time for new horns, have someone push horn button while you check for power at the horn, if theres power then replace the horns,sounds like bad horns to me,good luck.
Dec 17, 2009 | 2004 Pontiac Grand Am
No horn on 1997 pontian grand prix,checked fuse in fusebox,not the problem,what other solutions ?
The horn uses a relay switch which is also in the fuse box.
Find the relay switch and get the number off of it.
Check other relay switches in the box for the same number and "swap" the two to check the horn. If horn works, purchase new relay for the horn or the other accessory.
Sep 21, 2009 | 1997 Pontiac Grand Prix
2000 Pontiac Grand Prix horn sticks
THE HORN RELAY AND FUSE ARE IN THE UNDERHOOD FUSE BOX.
Jul 25, 2009 | 2000 Pontiac Grand Am GT
Where is the horn relay located on a 95 jeep grand cherokee?
On my 95 Jeep Cherokee Laredo, the horn relay is in a compartment under the glove box. Open the glove box and remove the three screws in the front on the bottom. Take the plastic cover out and you'll see a bank of relays. The horn relay is the one on the far left, closest to you.
Jan 27, 2009 | 1995 Jeep Grand Cherokee
Where do I find the horn switch on 95 Jeep Grand Cherokee?
 You should check to see if you have power at the horn first. If you do, you need a new horn. I believe there is also a relay involved. Sometimes these are interchangable. You can take a relay like the one for the A/C and swap it with the horn one and see if the horn works. That will at least eliminate the relay.
Horn
my first thought is for some reason it shorted out maybe in the steering column and has burnt out.put power right to the horn to see if it works
Jun 23, 2008 | 2003 Pontiac Grand Am
712T Keyless Entry 2-4but Rem Ob Relays Horne Logo
67 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
