Question about Bissell 6594 PowerForce Bagless Upright Vacuum
How to remove and clean the whole unit - Bissell 6594 PowerForce Bagless Upright Vacuum
  • 77 Answers
Start removing screws from around brush cover and back of unit. Usually all the screws are the same style/length but be sure to check while removing. Once you have all the covers off, you should be able to access all the areas that would be cleaned.
Posted on Jun 22, 2009
How do I clean the spray tip on my spotbot? It isn't spraying.
if it's not been used for a long time the pipes may be cloged up or the pump may be siezed up this video will show you how to dismantle it to check inside.
http://www.youtube.com/watch?feature=player_embedded&v=1sSVIu6arbY#!
Nov 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
No suction. model # 4495, bagless upright.
Mine wasn't picking up stuff either. After unplugging the unit, I had to take the yellow top off--unscrew the two screws that are hiding in the 4 indentations on either side. After removing that "hood" I then carefully lifted up the left side of the roller to free it of the belt. A middle piece came out too, which I carefully set aside with the screws. Then I had to clean that whole roller--including prying off the ends and cleaning the debris out of everwhere--so gross.
Then I restored the caps to the roller, threaded the roller back through the belt, turned the roller to make sure the belt was in straight alignment, put that middle piece back, restored the yellow hood, affixed it with the two screws, plugged the whole machine in, turned it on, readjusted the height, and voila!
Check your manual too. If its a gonner I used http://homeappliance.manualsonline.com/manuals/mfg/eureka/4490_series.html as a reference.
Aug 29, 2011 | Eureka 4495A Bagless Upright Vacuum
It is not picking up the dog hair and hoses are clear can i check where the roller is? how?lanye59@gmail.com
Apr 06, 2011 | Eureka Vacuums
My spotbot cleaner is no longer spraying water
I had the same problem, and found that the culprit was that the small filter element. about the size of a dime, that sits arount the nozzle activator (pin that depresses the clean water nozzel) was clogged with "gunk", and prevented cleaning solution from flowing into the unit.. It is easy to remove with a pair of tweezers or needle nose pliars.. rise it under water and reseat in the unit. You shoudl be aboe to perform the whole process in under a minute. This has happend to me several times... and am surprised the filter is not mentioned in the manual.
Aug 23, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
We have a spot bot we inheritied without a users
Jul 30, 2010 | Bissell SpotBot Hands-Free Compact Deep...
My Roomba says to clean the brushes when the brushes are already clean. Is there something to take apart to check? I have already taken the brushes out. I don't know the model number, I think it's the 500...
turn the unit upside down and remove the bottom pan should be 4 or 5 screws depending on the model.
next remove the 4 screws that hold the brush cartridge and pull the whole brush assembly out.
using a can of compressed air clean that whole assembly out there is a motor there so don't spray any cleaner on it. If there is surface grime you can use a clorox wipe or a damp cloth to get it all off.
this process should take about 10 minutes to do it properly use the straw that came with the compressed air to get in between the plastic shell and get all the dust trapped inside there.
make sure there is no dust trapped in the gears that drive the brushes.
put it all together and it should work.
Jan 12, 2010 | Roomba 3005 Pro Robotic Vacuum
The cleaning solution on my bissell spot bot is not being pumped through....on the stationary mode or the manuel hand held mode with the brush attachment
Nov 07, 2009 | Bissell 12005 Spot Bot Handheld Vacuum
The brush does not turn and the belt is not broken
it needs cleaned, it is very easy to take apart.
clean the roller,clean the ends of the roller and all ports. clean the whole bottom part of the vac removing any hair build up.
take it outdoors:)
Oct 21, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction isn't as good as it shoule be
I can help you there! Take off the whole filter unit (button near the handle) - take off the clear plastic dust bin. Wash the whole unit in water - I add a bit of washing up liquid and then keep rinsing (hose pipe outside is good) until water runs clear. Rest the right way up and leave it until completely dry. I presume you have cleaned the foam and gauze filter on the side of the machine? Finally, if you have a HEPA, then change that filter. Check the hose from the brush bar (about 3 inches long underneath the machine) isn't clogged and that should sort it.
Aug 02, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
146 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
