Question about Dream Maker Spas Pool & Spa
What does the code F3 mean on topside control panel (mini Balboa)?
SOURCE: it has an f3 code on it what ledoes it mean
F3 means fault code number 3, I think this is Power Supply, or Magnetron.
Posted on Feb 09, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
Regards,
Ian.
Coastsider
  • 331 Answers
SOURCE: We have a Great Lakes spa with a Balboa control
Contact Balboa's Customer support department directly at 800-645-3201, follow the prompts to customer tech support (or press 0 and ask for customer support). You will need to be at the spa, control panel open and ready to read off the chip number, and you will need to be proficient with a test meter (AC voltage). The SN error is related to a bad sensor(s), but can also indicate a failed board. An incorrect sensor set will also create this problem, so confirm you used the exact or compatible replacement. If the SN code issue is no longer a problem, but the spa is still not heating, look and see if the heater led is on. If it is, you likely have some burned relays on the board, which can be replaced cheaper than replacing the board. If you need more help, email me at info@coastsideservices.com
Posted on Aug 30, 2010
  • 111 Answers
SOURCE: Balboa Hot Tub (topside) control panel.
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
Posted on Jun 17, 2012
What does error code 00f mean ?
is the recirculation pump working or are filters clean that sounds like a no flow issue
May 17, 2014 | Balboa Instruments Pool & Spa
How do you turn a balboa spa on?
FYI...
Balboa does not make spas, just control systems.
but that is enough info to begin a troubleshoot process...
  • do you have anything displaying on topside control panel?
  • Fault codes?
  • When you say no power after connection to circuit what do you mean exactly?
  • Have you checked for burned system fuse?
May 04, 2014 | AO Smith Pool & Spa
Do I have the correct controller for my Hot Tub? I have a Jacuzzi Lexus L.C. with a Balboa F1089R1A processor. I ordered a topside control panel online and received a Balboa VL701S but nothing is working...
Curios, why did you order another control panel? I need some history, when it worked, how it failed, any other information like if it was moved or rewired for power...etc.
Nov 13, 2013 | Jacuzzi Home
I have a Balboa control board system (M2000 Programming and VL700S topside controller). I had to have the main board replaced recently because it blew up. Since then, the two speed pump is only one...
It sounds like it is 120/240 volt and that one of the lines is not working. Try turning off the breaker and turning it on again. You may have to use a tester to see where the fault is.
Sep 23, 2013 | Balboa Instruments Duplex Digital Panel 2...
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
Marquis Hot Tub, Instrument Panels (Balboa Instruments main and side auxillary) do not display the LED read out. Replaced main control panel twice, replaced 250 W. 3/10 fuse.
The topside controls aren't fused so the fuses wont be the cause.
It can only be either the PCB, the topside controls, or a bad connection at fault. Check that they are plugged in correctly, make sure that the PCB is configured correctly for your topside controls.
It's rare for both the main and auxilary topside controls to fail. You can try plugging in another main topside control without fully installing it... at least you can then return it (ask whether or not return are accepted, I don't personally accept any returns if parts are specially ordered) if it doesn't cure the problem.
Regards,
Ian.
May 09, 2010 | Balboa Instruments Duplex Digital Panel 2...
Pool & Spa Logo
170 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
