Question about RSQ HD-787
Cd tray will not open or load cd - RSQ HD-787
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 33 Answers
Try to use a safety pin to slide the tray out. u might see a small hole in the tray just slide in ur pin and push it, it might work
Posted on May 07, 2014
CD drawer will not open
Hello
There is a loading belt that fastened with a loading motor pulley, which gets the CD tray in and out. If this belt or the loading motro has trouble, the CD tray wont cole out, or load in properly. You have to check and find out which part is faulty. In normal cases, replacing the loading belt will rectify this problem. OK.
Dec 25, 2011 | Crosley 4-in-1 Entertainer CD Shelf System
When i switch my teacpdh300 cd player on the drawer open and when i close it, it reopens
hi,
Check the tray loading belt of your cd player. If the loading belt is over sized then this problem can occur. Normally the loading belt will become over sized after a few years of use according to the weather condition. . If so the loading tray will not go inside fully and will not engage with close sensing switch. if so the it will open automatically without any external command .Normally in all players the loading belt will be under the loading tray near the frond side of the mechanism. check the same. keep the player in eject position remove power and then try to replace the belt.
ok
Jun 16, 2011 | Teac PD-H300 CD Player
Player will not play a loaded CD and No CD message comes up Also CD drawer opens and shuts on it`s own !!!
the tray opening by itself could be a faulty limit switch on the tray mechanism
the switch tells the system if the tray has reached the open or closed position.
if it closes then opens itself then this is the most likely
check that first
could be closing then opening without actually loading due to the switch
you will need to open it up to find the switches
usually at the bottom front were the tray goes in
darren
May 28, 2011 | NAD C542 CD Player
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
Door keeps opening.
Replace the loading tray belt, it is quite a common problem on CD Players using the same Sony transport mechanism as your Arcam.
The belt loses its tension and cannot fully load and then spits the tray open.
When you try to load a CD you should be able to hear a whirring sound after closing the tray and that's the motor trying to lift the laser mechanism at full travel but is unable to hence not enough tension on the belt.
Hope this helps.
Jan 18, 2011 | Arcam Alpha 7SE
The tray on my Arcam Alpha 6 CD player will not eject and refuses to budge. Neither the remote control nor the load button on the front of the unit will make it open.
It's either the gear on the tray loading mechanism or it's drive belt. The gear is made of a soft material and the teeth wear down on the hard tray rack. Get hold of Arcam and order TP21H replacement part and belt. The same happened to me and the gear had perished. In the meantime stick something onto the front of the tray that you can use to pull it open after you have pressed the 'load' key. Place your CD in the tray, press the 'load' key and push the tray closed manually. The player will work like this until you can replace the gear/belt.
Jul 04, 2010 | Audio Players & Recorders
Cant load cd into cd drive
Sounds like the tray is not comming out completly. Before you eject the tray you should notice a very small hole. take a paper clip and straighten it out and push in this hole. The tray will/should start to come out push the paperclip in as far as you can and check to see if this will allow the cd to stay on the tray.
Mar 31, 2010 | E-Machines eMachines Desktop PC
CD tray automatically opens, when entered, cd not readable
Please clean tray loading section and specially loading belt. This cleaning will required to apart unit. If you are familiar with such kind of job, go ahead or ask help of local tech.
Jan 11, 2009 | Sony DAV-S300 System
Loading tray will not load or close-reopens immediately
Sounds like the tray position switch has gone wrong.
Sep 30, 2007 | Onkyo DX-C340 CD Player
CW088D CD-RW drive
All you can do is the usuall checks:- try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the pc and then the drive will be re installed with drivers automatically. if it still won't eject then there is a drive fault.
Apr 23, 2007 | CyberDrive CW088D CD-RW Burner
RSQ HD-787 Logo
61 people viewed this question
Top RSQ Computers & Internet Experts
David Payne
David Payne
Are you a RSQ Computer and Internet Expert? Answer questions, earn points and help others
