Question about Fuji FinePix F480 Digital Camera
Power button My power button will not power on. I have a new battery installed.
  • 4 Answers
Hi There should be a reset pin hole on the camera somewhere. Check the manual for the location. Then press the on button and use a paper clip to insert into the pin hole right after. This should rset the internal computer. Hope this helps.
G.Evans
Ontario, Canada
Posted on Jul 09, 2009
Ceiling fan
Remove batteries from remote and press all buttons to eliminate possibility of a "stuck" button. Reinstall batteries or install new batteries and try operation. If no luck, disconnect fan power at the source, not at the fan. Reconnect power and try operation. If no luck, the receiver in the fan may have failed.
Apr 25, 2014 | Televison & Video
Power Button Wont Work
If there is no power at all the problem could be that the Power Cord is bad or the Motherboard is bad. The guys at: http://www.generalsystemsconsulting.com can help you. They will fix it and ship it back by Fedex or UPS. Get a quote from your local computer shop then try them.
Mar 10, 2012 | HP G60-235DX Notebook
I HAVE A A22M THINKPAD THAT WILL NOT TURN ON. HELP
Thanks for using FIXYA,
well, that sounds a motherboard problem, try to do this before we go furter:
take the battery off the machine and disconnect it from power, press and hold the power button at least for 30s.
then without the battery on , just the power cable, turn it on, if that dont works you need to repair the motherboard.
Thanks and dont forget to rate this solution
Anything else just let me know
May 27, 2011 | IBM Computers & Internet
C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Sep 28, 2009 | Compaq Computers & Internet
Dell e510 won't make it to post
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Nov 09, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Power button light turns on and off continuously with no other signals appearing!
Just repaired one with the same problem. I finally installed new power button board, and motherboard. good luck and hope this will solve ur problem. By the way try the new power button board first it may save ya the cost of a new motherboard. Joe
Aug 19, 2008 | HP Compaq Presario C500t Notebook
Camera problems
Turns out the brand new batteries I installed were dead.
Mar 18, 2008 | Samsung Digimax S500 Digital Camera
LCD Replacement
Did the connector from the replacement LCD inverter fit in the socket of the motherboard? When you were replacing the LCD, did you have the battery out of the unit? And finally, have you attempted to start the laptop with the power cord in, but the battery out? I'm not familiar with the mx6931, but can you press the power on button without the trim piece that sits above the keyboard?
Sep 15, 2007 | ASUS F3F Notebook
Fuji FinePix F480 Digital Camera Logo
170 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
