Question about Vacuums
RUNNUNG HOT I HAVE A BOSCH VACUAM CLEANER MODEL No BSG62082/03 IT IS TWO MONTHS OLD, THE CLEANER DISPLAYS''BAG FULL'' ALMOST IMMEDIATELY AND THE HEPA FILTER BECOMES VERY HOT REGARDS DSVID WRIGHT
  • skyeshiner Jun 22, 2009
    get immediate assistance! thats all you can tell me?
    Top Expert:
  • Vacuums Master
  • 81,294 Answers
Check the hose for blockage, very common.
Posted on Jun 22, 2009
  • Marvin
    Marvin Jun 22, 2009
    what are u talking about, I said to check the vacuum's hose for a clog, never said to "get immediate assistance" are u reading my post???? check the hose. Your rating is unfair, a clogged hose is the most common cause of this, and we do this for free on our own time, since at work i make money for advice this is a pretty fair deal. I will not help anymore until u change the rating. Sorry.
My vacumn cleaner stinks when in use, but it is not the bag to full?
I only know how to do things in a systematic approach so if I ask to many questions and this response seems to wordy disregard.
First: What type of stink are we talking about? Burned Rubber like a belt being worn out? Or stink like a junk yard?
Second: Do you use through away bags or just empty the bag and and reuse it?
Third: Does it have any air filters (Hepa stuff like that)?
Fourth: If you remove the bag from the cleaner and run the machine do you still have the stink?
These aren't solutions as much as troubleshooting.
Jan 22, 2011 | Kirby G5 Bagged Upright Vacuum
Vacuum will no longer turn on. Vacuum bag was
Same problem. I suppose BOSCH dumped these into the market and have chosen to disown them. Support is pitiful and vacuums have also been taken off their website. Too bad, was a nice quiet product for the 2 months it worked. Solution = new, non-BOSCH vacuum.
Oct 04, 2009 | Bosch 12-Amp Formula Canister Vacuum with...
Where does the hepa filter go
Look for a removeable grille at the top or back of the vac shaped similar to the filtter. The filter is an after filter so it sits beyond the bag
Sep 10, 2009 | Bosch BSG71310UC Bagged Canister Vacuum
The top of the vacuum cleaner gets very! hot with little use of hand wand. it is a majestic model with chrome top about 6 years old
the exhaust is from the top so it will normally get pretty hot. If the machine shuts off, then there is a clog, or a full bag. Most of your machine is actually plastic, so examine it closely for warping or any discoloring. Also if it sounds funny you might want to have someone check the motor.
Aug 19, 2009 | Vacuums
Can't refit dustbag to bosch ergomaxx barrel cleaner
The bag slips into the holder which should be attached to the machine. If you have taken this out by mistake and thrown it you'll have to contact Bosch to order a new bag holder.
Jan 22, 2009 | Bosch 12-Amp Formula Canister Vacuum with...
Vacuum Cleaner Bags
REQUIRE REPLACEMENT OF DUST BAG BRAND BLACK AND DECKER MODEL VB 1800 XE HEPA 13.PLEASE SOLV THIS PROBLEM OR COMPATIBLE DUST BAG
Aug 27, 2008 | Black & Decker HV6000 Bagged Handheld...
Bosch Vacuum Cleaner: I changed bag. Cleaned out all suction hose and hepa filters, however, my 1450 w 12 amp upright vacuum cleaner will die after five minute run - overheating. Please advise.
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 16, 2008 | Bosch Vacuums
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the Hepa filter on this model (*this model uses a vacuum cleaner...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=794479
Generic problem for all Vacuums
Posted by gohornsgo on July 17, 2008
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the HEPA filter on this model (*this model uses a vacuum cleaner bag also).
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to clean the HEPA filter is to take it outside and use a blower over the trash can and blow off the dust and dirt, or use things like an old paint brush and brush it off, or you can vacuum it off with another canister vacuum or shop vac if you have an extra one. For the best filtration is to replace it, there fore the air flow will catch most of the dust and dirt and then you would have to watch how fast it gets dirty and then do the maintenance.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
It just shuts off!
Some of these have the Hepa filter on the back, if so there will be a door to access it. If there is one, some had a reset button that you push, mainly for when you change the fifter, if it has one, push that reset, if it needs to be re-set, it will shut off after a seconds. Remove the Hepa filter and look see if there is a reset button. https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM, this will give you a link for a user manual. If you disconnect the hose, will it shut off or stay on. If it stays on then there is a clog either in the hose, wands, or the inlet down by the brush roll. If it goes off, and there is no reset by the Hepa filter, then there could be a problem with the motor or motor protector.
Jan 30, 2008 | Bosch BSA2200UC Compact Plus Health Guard...
Vacuums Logo
43 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
