Question about Cooktops
E039 Have a Frigidaire FPCC3685KSA cooktop that had needed a relay board. Installed relay board, but now have E039 code. Found out it is for configuration, but was told to push warm button while turning other knobs. I don't have a warm button, so am confused what to do. How do I configure it so I can use the cooktop again?
  • 4 Answers
Usually E0 39 or E 39 or 3 039 is mismatch between your new board and current boards. Do a reconfig: install new board. Plug in. If you get the 39 code push one of the burner on/off buttons to make the beeping stop and blank display. Then, push and hold right front and right rear UP buttons simultaneously until 88 appears in display. Then press and hold left rear and left front UP buttons until beep sounds and configuration starts. A few seconds later it should clear and be all set! Hope this helps.
E039 - /uploads/images/9_6_2014_11_25_49_pm.jpg
Posted on Sep 06, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Hi I,m not sure on the model but I suspect it needs to be turned off at the power and leave it a few minutes then hopefully the program will re set itself. Good luck
Ray
Posted on May 10, 2014
  • Kalpana Patel
    Kalpana Patel May 12, 2014
    Thanks. We already tried that and it didn't work.
4 Suggested Answers
SOURCE: Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
We are having the same issues it sounds like as Larry is...
Posted on Jul 26, 2010
  • 1416 Answers
SOURCE: My frigidaire gas cooktop is
Yes.
What this indicate is that there has been a bring up/meant wire from the wire connection from the main power supply (from the wall) connected to the burner. there are two of solving this problem bellow
put off the power supply from the wall or were ever the power supply is from to put of the the element then two unplug the wire from the wall the unscrew the range the trace the wire down to element (heat provider) from the back properly then test the round the wires and replace the weak wire among them.
You can get a wire replacement from any technician store around your local area but if you are unable to get if your self then you will have to invite a technician to visit your range in order to avoid more damage on it.
Thank you and thanks for using fixya..
Posted on Sep 15, 2010
SOURCE: I have a Frigidaire Ceramic Glass cooktop.the main
I'm having the same problem! Except I'm not guarenteed any heat even on high.
Posted on Jan 07, 2011
I have a frigidaire ples389dcc as soon as i plug it in it give me a pf code
Good Morning Paul, thank you for your post!
Based off what you have described your Frigidaire range, PLES389DCC, is providing you with an error code of "PF" and "F1" as soon as you turn it on. An error code of "PF" stands for power failure this could be a possible problem with your control panel or power cord.
The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F1" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Apr 10, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
Electralux Surface Cooktop, with code---E----40
Hi Linda Wallman, thanks for your post!
I see that your Electrolux cooktop is displaying an "E40" error code. Typically, the "E40" stands for no communications, shorted bus. This could be an internal communication error with your left control board, relay board, or filter board. I would recommend getting a technician out to your home for proper diagnosis and repair. I hope this is helpful. -Matt
Oct 20, 2014 | Electrolux Cooktops
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
What does a F550 code on a Frigidaire Stove mean?
That means that the oven control board is having problems. Replace it.
Feb 06, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Frigidaire gas stove beeping
Most likely the control board, is it showing an error code of any kind?
Nov 17, 2012 | Frigidaire Gas & Electric Stove/Oven/Range...
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
We live in the 45371 zip code -- Tipp City Ohio-- we cannot get our Jenn Aire cooktop removed in order to get our Frigidaire installed. Do you know anyone in our area we can call? We tried ourselves but...
Sorry to read about your problem, I hope this helps you out.
just look for a handyman service here are a couple
695 East Shoop Road
Tipp City, OH 45371
(937) 559-3590
937-396-6713* 115 East Maplewood Avenue, Dayton, OH 45405
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Frigidaire 36" Built-In Electric Cooktop -...
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Frigidaire smooth cooktop PLEC30S9EC
Smalltree, You may want to make sure that they have 220 wired to the cooktop. I've seen a lot of new construction where they are hooking the cooktops up to 120V and wondering why they're not working. Check this first and post back..Catriver.
Nov 02, 2006 | Frigidaire PLEC30S9EC Stainless Steel...
Cooktops Logo
345 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
