Ricoh aficio 1113 black lines.
Black lines down the middle
  • 82 Answers
SOURCE: black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Posted on Apr 06, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICOH AFICIO 1022 ADF scanning with a black line down right-hand side
There is a tiny spec on the scanner glass. Cleaning it will make the line go away.
Posted on Jul 11, 2008
Touch2Heaven
  • 145 Answers
SOURCE: RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Posted on Oct 15, 2008
  • 4 Answers
SOURCE: Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Posted on Dec 05, 2008
SOURCE: ricoh 1113 pass word removal process
sc322-00 on ricoh 350
Posted on Jul 11, 2009
Ricoh aficio 2022SP prints black line across middle of page
Remove the OPC unit,clean the charge corona,charge corona grid,clean or change the OPC drum cleaning blade.
Jan 26, 2013 | Ricoh Aficio 2022 Black and White Copier
Hp Laser Jet P2055dn printing black line down the middle
The line in the middle of the page is caused by a damaged or worn fusing assembly in the printer. Here is a link to an article showing this issue on the Laserjet 2100 printer and how to replace the fuser unit. Your printer just needs to have the fuser replaced, it is part number RM1-6405 and is available from Amazon
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Jul 19, 2012 | Ricoh Aficio CL3500N Laser Printer
Ho una fotocopiatrice Ricoh Aficio 1113, cpmare sul display SC546. Come posso risolverlo? Vi ringrazio in anticipo
SC546 - Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause:
• Thermistor defective
• Power supply unit defective
May 27, 2011 | Ricoh Aficio 150 Copier
I have a Ricoh Aficio CL3500N When I print a vertical page there are thin black lines going down the left side of the page. What causes it?? And what can I do??
Hi, thin black lines are most likely (but not definitely) caused by something in the black PCU (photoconductor unit), either the drum or the charger. Replacing the black PCU will likely get rid of your lines. The Ricoh code for a black PCU if you don't already have one is 402448.
Jan 29, 2011 | Ricoh Aficio CL3500N Laser Printer
Ricoh CL7100- Black Dots on all printouts
What are the correct colour settings for optimum colour printing for Ricoh Aficio Cl7200
Apr 12, 2010 | Ricoh Aficio CL7200 Laser Printer
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
I have problem with Ricoh Aficio 1113, error code sc320
I am assuming you really meant an Aficio 1013 - SC320 indicates a polygonal mirror motor failure. This motor drives the mirror that distributes the laser to the drum. Could be a defective motor, poor connection between the motor and the BICU - one of the motherboards, damaged cable or defective BICU.
This will require a service call. Probably looking at an hour to diagnose the exact problem and an hour or two to repair plus parts. Could be as simple as a loose connector --- doubtful, but you never know.
Dec 24, 2009 | Ricoh Aficio 150 Copier
Black smudgy streak in middle of printed page
Thank You,
Mikey
Feb 26, 2008 | Ricoh Aficio AP3800C Laser Printer
jasbo
jasbo
