Question about Garmin Fishfinder 90
Black white red. Two of the wires go to the battery - what about the third?
Utilitech Wall Timer #0192773 does not switch landscape lights on? Replaced Intermatic that had 3 wires. Black to Black, blue to black and red was capped. Utilitech came with 4 wires - black, white,...
Old timer: Intermatic EJ500 & ST01C timers have a battery. Battery operates the clock motor. Red wire is for 3-way circuit [a hallway with 2 switches is a 3-way circuit].
Utilitec timer, clock runs on 120Volt circuit instead of battery. So clock has to have power.
How to connect wires:
Black timer wire connects to hot wire from breaker box.
Red (or blue) timer wire goes to landscape lights.
White timer wire connects to white neutral wire [or if no neutral is available, connect to bare ground wire].
Green timer wire goes to bare ground wire.
How to find black hot wire and white neutral wire inside box
: Disconnect and separate wires so you can test. Use ordinary tester. Power is on. There is only 1 black hot wire inside each electrical box. Test each black wire to bare ground until tester light comes on > that identifies the black hot wire. Next, test black hot wire to white wires until tester light comes on > that is the neutral wire. Exception: This test does not necessarily work with 3-way switches since they reverse each time switch is thrown.
Sep 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Replacing 3-speed fan swith, using westinghouse 77021. Black (hot wire) to L, red to 1 , outer black to 2. What is 3 STRIP for?
the third wire should be for neutral (White) This is an incomplete request,
Is this a three wire pull switch or are you hooking up to a light switch on the wall.
but what I know is Black hot
Red switch
white neutral
If it is NOT WHITE do not attach it untill you have someone over to help you
Jul 22, 2010 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Electric trailer brake hookup
Truck Brake control
Red/Black stripe Black
Blue Blue
Lt. Blue/white stripe Red
White White
Orange Not used
Jun 28, 2009 | 2006 Toyota Tacoma
What colors on electrical cord go with what screw on dryer?
black on first screw/white on middle screw/red on third screw/green to the screw on case that says grnd.
Jun 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
May 24, 2009 | Ovens
Motherboard wiring
Green/wht normally = Reset or Power LED
Red/wht normally = HDD LED
And is the third red/BLACK?
There should be a label on the black pin jumper at the end of each wire.
Does it say anything?
Jan 16, 2009 | E-Machines eMachines Desktop PC
Wiring motion sensor light
Hello Lesco1, first check the bulb, second I need Mgfr & model, third attempt BK from house to R of sensor & BK from sensor to BK of bulb.
Nov 06, 2008 | Electronics - Others
Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Stovetop 3 wires to wall 4 wires
I'm assuming this is a 220/240v unit. The wall has two blacks, each with reference to white is 120v. Since you need 240 volts, you need to use both blacks. The third wire you'll need is ground. ALWAYS make sure you use a ground wire!!
Realistically, the white is connected to the Ground terminal in your circuit breaker box. Best practice says cap off the white, and use the GROUND.
Mar 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Garmin Fishfinder 90 Logo
29 people viewed this question
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
