Question about M-Audio Studiophile BX5 Main / Stereo Speaker
Bx5a monitor speakers
One just "blew" i guess. it pops when i turn it on/off, even when not connected to audio source
Check the capacitor, if its swollen or rusty it needs replacing, also check the fuse.
Posted on Jul 29, 2009
How to replace capacitor on M Audio bx5a speaker
http://mr-ives.blogspot.nl/2011/09/mending-pair-of-m-audio-bx5a-monitors.html
Apr 20, 2013 | Klipsch Synergy Sub12 Subwoofer Speaker
Was connecting subs to speaker connections when it popped, turned off and will not turn back on...VSX-518-k
You probably blew a fuse. It should be marked on the back next to where it tells you to turn the power off before connecting speakers.
Good Luck,
Gil
Jul 19, 2011 | Pioneer VSX-518-K Receiver
I'm a video editor (MAC OSX). I playback audio at fairly low volume. Recently, I turned on my speakers (BX5) and only the R came on. L was dead and inspection revealed it was "blown". Can't...
Hi, cases like that always comes u. Earlier you said just replaced it, that's not too good for anew monitor speaker.
You could test the fuse inside the speaker if it's still working, might be power fluctuation that might have caused it to blow.but you need to test it. If it is the fuse,fine! you can replace it, it does not cost much to replace.
Also if i can recall,most new stuffs always comes with guarantee with it,right?. I would suggest you could take it back and get a replacement, and i guess if they see it,since it is on guarantee,they can fix it for you without even charging you a penny.
Hope that helped.
Thanks and feel free to pass on your comment.
Thanks for using fixya..
Jan 12, 2011 | M-Audio BX5a Speaker
I have connected my BX-5a monitors to the fast track audio pre-amp with 1/4 inch to RCA adapters, which is connected to my Mac book pro. I am still not getting any sound out of the monitors. What do I do?
I would suspect the Mac isn't passing any audio out. Test it with headphones before we troubleshoot the audio hardware. OR, connect a different audio source to the preamp to see if it works with something less complex than a Mac.
Jan 10, 2011 | M-Audio BX5a Speaker
So I've kept my Studiophile BX5a Deluxe monitors in good shape, but I noticed that every sound I tried to generate via Ableton Live on my Mac, a buzzing sound would accompany the sound. For example, I...
See if you can isolate the buzz to one woofer or tweeter. If a woofer, gently and evenly move the cone in and release to feel / listen for scraping. If you notice any scraping, the voice coil could be shot - a small bobbin of copper wire may have deformed andis now rubbing. Occasionally if a speaker is dropped, the magnet can shift, which will then rub the coil.
In any case, if there is coil rub that causes the buzz, you need to replace that driver.
If the buzz is electronic in nature, assuming these are the powered versions, a qualified service tech will have to diagnose and repair.
Jan 06, 2011 | M-Audio BX5a Speaker
Where do I find a replacement woofer for a bx5a monitor
http://reconingspeakers.com/product/m-audio-bx5a-woofer/
Jan 02, 2011 | M-Audio BX5a Speaker
I got a pair of bx5a What do i need to connect
Here is your resolution that how you can connect your BX5a to PC.
well I had provided some pics attached in that I had marked and given some information follow that accordingly and you will be able to connect it your PC.
But you need XLR code through only you can connect it to your PC.
If you still have nay other problems regarding same or any other do reply me.
Naiven.
May 24, 2010 | M-Audio BX5a Speaker
No sound from M-audio BX5a monitor
I have a pair of BX5a monitors hooked up to a video editing suite. One of the monitors is off. They are powered to a working electrical supply. They are driven off a Mackie DFX-6 with a 1/4" unbalanced connection. No blue light on the monitor, no sound or hissing on that...
Jan 31, 2009 | M-Audio BX5a Speaker
M-Audio BX5a Speaker Problem
Not sure i can help with the led problem but i just fixed a hissing problem with one of my BX5a monitors. It developed a hiss when on (both tweeter and bass) and a very loud thump when switched off. I found a slightly swollen power filter capacitor on the internal board. They are the two biggest black capacitors, labelled as 25v 6800uf. Only one of these was bulging. The tops of these should be totally flat. The indented X on top of the caps make any bulge easy to spot. Worth opening it up and having a quick look. I could only find 35v 6800uf caps at my local electronics store but they did the job ($3 each). I swapped both out and it's now working great. An easy DIY fix, just be sure to always have the power cord unplugged before you put your hands anywhere near the guts of the thing. Hope it helps.
Sep 17, 2008 | M-Audio BX5a Speaker
M-Audio Studiophile BX5 Main / Stereo Speaker Logo
704 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
