Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
Why is water not shooting from ventur nozzle?
How can I troubleshoot the water management system
  • 2,760 Answers
Ck venturi intake screen !!
Posted on Dec 11, 2014
Kenmore Water Softner Model 625388270 Serial 12756 - Water above the salt level. I have cleaned the venture nozzle. Did not help
Did you adjust the float level in the unit to 10" from the bottom of the float to allow only so much water in before it closes off? Did you check to make sure your drain is properly draining?
Aug 05, 2013 | Washing Machines
GX 08 spray gun problem
drain your system of pressure. remove your air cap and nozzle from the gun. slowly increase fluid pressure till it comes out of gun. this will clean out debri from gun. reduce pressure so you don't wast anymore fluid.
clean nozzle properly / completely
clean aircap. properly / completely
inspect needle tip for abnormal wear.
if cleaned properly you will find your gun works much better.
Oct 17, 2009 | Wagner GX08 Airless Spray Gun
Front windshield washer doesn't work but rear washer does in 2003 chevy venture and the fuses seem to be ok
either the hose to the spray nozzle of the nozzel itself is plugged up
unhook the hose to the nozzle and blow thru it with compressed air
Sep 26, 2009 | 2003 Chevrolet Venture Passanger
Rooster tail is not shooting high
If the waverunner is performing normally as far as throttle response and top speed, then the rooster tail not shooting as high as it used to indicates there is a restriction in the nozzle for the rooster tail, not a problem with the ski. Unbolt the rooster tail nozzle from the steering nozzle and inspect it for debris.
Jul 13, 2009 | Yamaha 12V Air Pump
2000 Chevrolet Venture front winshield washers won't spray
If it shoots from the pump without lines connected, then there has to be blockage somewhere. You mentioned you blew the lines out, did you blow directly back through nozzles themselves?
Jan 12, 2009 | 2000 Chevrolet Venture
Krups xp7230, no water running through nozzles
Yes, you're machine is identical to the xp7240. Look up the post on leaking xp7240 and follow the instructions on how to open the machine and fix the valve.
Jan 06, 2009 | Krups XP7230 Compact Super Automatic...
Water pump nozzle hose
what type of hose is it? is it a small hose because usally there is not a hose coming out of the water pump itself they are breathers from the fuel tank or some or something else that needs to be vented and thats where they route the hoses
Dec 18, 2008 | 2008 Yamaha Royal Star Venture
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
83 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
