Question about Craftsman Garden
How do you replace a drive belt on a RE 2000 Craftsman ride n mulch mower
I was mowing and it just came to a stop, still running just would not move in any gear, when checking it out I found a broken drive belt, I need to know how do I install another one.
  • 42 Answers
SOURCE: how to replace drive belt
here is a diagram that will hopefully help you. let me know if it helps, or if you need further assistance. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chus%5cimages%5c33%5c28%5c0009.tif&ilsc=16&iliv=0&ilbr=0&ilif=g&ilre=8
Posted on Mar 15, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
  • 376 Answers
SOURCE: Craftsman 19hp won't move when in gear
There is a square key about 2 " long that fits in the slot on the axle and wheel and locks them together.. You probably didn't see it when putting tire back on and knocked it out. If you go back where you removed tire, you'll find it laying on the ground.
Posted on May 27, 2009
  • 376 Answers
SOURCE: need to find illustration of mower deck drive belt
Posted on Jun 01, 2009
My Quest stopped while I was mowing . Engine runs pro working but it will not move . Why my zero turn will not move forward or reverse?
Either the transmission drive belt has broken, jumped off the pulleys, stretched or a tensioner spring is broken.
Oct 14, 2017 | Garden
Engine runs on my swisher 2560 but will not move, stopped while mowing
Drive belt may have broken or idler pulley could have malfunctioned or drive belt could have just came off alignment.
Sep 10, 2017 | Swisher Garden
While mowing with my john deer 125 it just stopped moving
Check for the drive belt to have come off or broke.
Jul 23, 2017 | Garden
Mowing and made a small bang just stopped motor running ok but wont drive any suggestions thanks
check for a broken shear pin in the drive gear
check for broken drive shaft or stripped gears
Oct 01, 2016 | Garden
LA105 mower won't move when put into gear
Is this happening in all gears or just one? Is the motor bogging at all. If not chances are the problem is in the drive belt to the transmission or in the transmission itself. Check to make sure you are getting it into gear. you should be able to feel the transmission hit a notch for each gear. If you can't, chances are the little module in the top of the trans that sets the gears has broken and needs to be replaced. Often these get sticky before going bad. If the motor is running normally though, it's not the engine, it's drive belt or transmission. with the mower off, you can check the drive belt tension by simply having the clutch pedal in the out (drive) position. In that position the drive belt should be tight enough that you really can't slide it in either direction without causing motion on the motor pulley. If it has slack in it, then your clutch is probably out of adjustment or your drive belt has stretched beyond it's working life. Have you smelled burning rubber at all.. if so the belt is probably slipping. If not, it's more likely that it's in the transmission.
Nov 02, 2012 | Garden
My husband was injured and cannot replace the main drive belt for our riding lawnmower. Is there a place to get the schematics of how to put it on? If I have a picture I can do it. Model 917271041,...
Normally the belt diagrams are in the owners manual. Seeing this is a 12 year old machine the diagram stickers are possibly gone, but the drive belt diagram is normally on the bottom side of the foot rest, and the mower belt is on the top of the mow deck. Both are typically on the left side of the tractor as you sit on it. Please vote 4 thumbs up. Thank you.
Here is the link to a typical 42" Craftsman mow deck belt:
http://www.askmehelpdesk.com/attachments/tools-power-equipment/21777d1247094945-craftsman-lawnmower-belt-diagram-aypwobrk.gif
Oct 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
